Problem with WPA and intel 3945ABG NIC
l.buschi
Level 2
Level 2
Hi all,
I have very big problem with wireless WPA (TKIP) + Radius and NIC 3945ABG INTEL.
Connectivity is flapping.
No problem if I configure the AP with WEP.
Laptops are DELL and driver is the last for these PCs.
Can anybody help me^?
Thanks a lot
Johnny
pmccubbin
Level 5
Level 5
Hi Johnny,
Is the NIC set for Power Saving Mode? If so, try setting it to Constantly Awake. I've seen this issue before and that's what we ended up doing. Let us know.
Hope this helps.
Best,
Paul
Scott Fella
Is it the latest driver that Dell has issued or the latest driver from windows update or intel. You should use the latest driver from Dell and if that is an issue, then use one version older.
-Scott
If this is a controller based solution you can increase the user timeout setting from 5 minutes to a longer setting.
