qos apply between the AP and WLC?
raymond wang
hi
Most of the AP have configured as FLEXCONNECT MODE. I was wondering if there is QOS I can apply so that when traffic is high, the AP still can connect to the WLC..
manassin
Hi Raymond,
AAA Overrides of Bidirectional Rate Limiting on an AP and Controller
You can have AAA overrides for FlexConnect APs to dynamically assign QoS levels and/or bandwidth contracts for both locally switched traffic on web-authenticated WLANs and 802.1X-authenticated WLANs. Both upstream and downstream parameters are sent to the corresponding AP.
This table shows the bidirectional rate limiting implementation:
Table 1 Bidirectional Rate-Limiting Implementation
Upstream/DownstreamLocal ModeFlexConnect Central SwitchingFlexConnect Local SwitchingFlexConnect Standalone
Per-Client DownstreamControllerControllerAPAP
Per-Client UpstreamAPAPAPAP
This table shows the order of preference for local and FlexConnect central switching:
Table 2 Rate-Limiting Parameters
AAAQoS Profile of AAAWLANQoS Profile of WLANApplied to Client
100 Kbps200 Kbps300 Kbps400 Kbps100 Kbps
X200 Kbps
XX300 Kbps
XXX400 Kbps
XXXXUnlimited
reffer to the link:
Thanks and regards,
Manas Pratap Singh.
Stephen Rodriguez
Yes, you want to make sure the AP port is mls qos trust cos, same on the WLC port(s).  But for this to work properly, you need to be tagging the mgmt interface on the WLC.
Then you prioritize the traffic using UDP 5246
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
If mgmt frame are the one most important, I would say "mls qos trust dscp" at FlexConnect AP connected switchport is required. In this way all all managment frames coming from FlexConnect (untagged frames) will go as CS6 & get priority within your rest of the network. Makesure this value preserved till it reach the WLC in your network.
If you trust CoS, then all management frames will be marked as DSCP=0 (as no vlan tag or CoS for management frames).
Refer this post about QoS in H-REAP (or FlexConnect)
http://mrncciew.com/2013/07/23/qos-for-h-reap/
Rasika
**** Pls rate all useful responses ****
