Showing results forĀ
Search instead forĀ
Did you mean:Ā
Question on the IPAD users and Cisco Wireless
michael.lussier
I have setup a WPA2 PEAP network for my IPAD Users. What I have noticed is that none of them show up on the maps in WCS.7. I see all of my other pc and linux users. I can find them by mac & IP  in the WCS system. has anyone seen this before.
Michael
Nicolas Darchis
Real time location imply the client either sends a lot of traffic or is CCX compliant.
The IPAD is saving its battery as much as possible so it sleeps as much as possible which makes it hard or impossible to locate.
If you search for an IPAD mac address on WCS and in the client details select to view the device current location, WCS will disconnect the client to force it to reconnect and that usually allows WCS to locate it properly.
Hope this clarifies.
Nicolas
Don't forget to rate answers that you find useful
