Question re. WiFi Protocol in use
shanemoss
Beginner
Beginner
Hi Folks,
A list of all the wireless clients on my WCS shows among other details the protocol in use.  I have a mix of 802.11g, 802.11a, some 802.11n clients and another called "Mobile", does anyone know what the Mobile protocol refers to?
Thanks in advance,
S.
Scott Fella
Mobile clients are clients that are anchored to another WLC. Typically you will see this in a foreign to anchor WLC setup when the anchor is in the DMZ. However, depending on how you setup your wireless, it might also be layer 3 roaming that has to anchor back to the WLC the user was initially on.
-Scott
8 Replies 8
Hi Shane,
1) Do you have multiple WLCs and does the client do L3 roaming ?
2) How do you see the same client on the WLC
     show client summary
     show client detail advanced
Victor V
*****Help out other by using the rating system and marking answered questions as *****Answered"*****
Regards Victor V *****Help out other by using the rating system and marking answered questions as *****Answered"*****
Scott Fella
-Scott
Thanks.
Shane,
Out of curiosity.... were you seeing this on a guest anchor?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Scott,
How can I tell which is the anchor controller, I have a mobility group but don't predefine which controller is the anchor?
Regarding my original question, a little more information that I should have spotted originally.  With the clients that are listed as using "Mobile" protocol, they also exist in the list of clients as using 802.11/a/g/n as their protocol which would indicate that they have indeed roamed to a new controller.
Thanks again, S.
Post the show wlan
Scott
-Scott
Scott, please see below; there is no entries under Mobility Anchor List, perhaps because Auto Anchor is disabled.  This raises another question for me.  Without auto anchor and without statically defining mobility anchors (I can't see where these would be configured) what will happen in the event of a controller failure?
(WiSM-slot9-1) >show wlan 3
WLAN Identifier.................................. 3
Profile Name..................................... Guest_Smartfone
Network Name (SSID).............................. Guest_Smartfone
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 100
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ guest_smartfone
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Enabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority..............................
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ X.X.X.X 1645
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
WLAN ID     IP Address            Status
(WiSM-slot9-1) >
How about your show mobility summary... if you have multiple WLC's and no guest anchor, then maybe the users is roaming to the other WLC.  What WLC and code?
Scott
-Scott
