Radius on C9800 issues
Hashen
We configured our C9800 with a Dot1x SSID.
when clients enter access to connect, we have the following message
Mar 7 14:11:37.180: %DOT1X-5-FAIL: Chassis 1 R0/0: wncd: Authentication failed for client (f446.3742.4aa0) with reason (Cred Fail) on Interface capwap_900002bf AuditSessionID FA28A8C00002E733193D09C3 Username: Radiustest1
whereas when we do the test from the C9800 the authentication is ok
So this was never worked before ?
is this first time installation ? what source for the user authentication ?
https://howiwifi.com/2020/07/21/cisco-9800-802-1x-eap-user-authentication-with-windows-radius-nps/
BB
9 Replies 9
marce1000
       - Check the radius server's logs for the particular authentication (the one failing),
 M.
balaji.bandi
what is the code onthe Cat 9800 running ?
what Radius you have ?
what client you testing ?
is the client has certs and user authentication ?
if the Windows check below thread :
https://learn.microsoft.com/en-us/troubleshoot/windows-client/networking/802-1x-authentication-issues-troubleshooting
also verify the config WLC 9800 :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213919-configure-802-1x-authentication-on-catal.html
BB
Hashen
@balaji.bandi , Below is my feedback
what is the code onthe Cat 9800 running ? -----------17.3.4c
what Radius you have ?----------- NPS (Windows)
what client you testing ? (MS Windows, IOS, Android)
is the client has certs and user authentication ? no certificate
I remind you that the test done from the cli controller mentions that the client is authenticated.
but from a wifi client it doesn't work
                          >...but from a wifi client it doesn't work
    - Check the radius server's logs for the particular authentication from the wifi client
 M.
BB
Yes this is the first installation and it never worked.
The source is the active directory
I check with the document in your link.
If you have anything else to do on the C9800, please share it with me.
THANKS
                   >...If you have anything else to do on the C9800, please share it with me.
 - Not on the C9800 but on the radius server(s)  Check the  logs for the particular authentication from the wifi client
 M.
Thanks also to you @marce1000 , capturing the logs guided me.
Gratitude
Thank you @balaji.bandi  it was more at the NPS level the problem.... and your document helped me a lot.
Gratitude
