Relocate Building to Different Campus in PI
I must be missing something obvious, but I am not able to figure out how to move a building to a different campus in PI 1.3.
Thanks in advance
From the configuration guide http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/configuration/guide/maps.pdf
After adding a new building, you can move it from one campus to another without having to
recreate it.
Does anyone know off hand how to do this task?
Rasika Nayanajith
It is straight forward.
First go to "Monitor -> Site Maps" & then select the building you want to move. Then choose "Move Building" option from the dropdown list & hit "Go".
Then it should ask what is the "Target Campus". Once you selet it click "OK", That's it, your building should move to the required campus. Below shows a screenshot of what I explained here.
Pls mark this thread as "Answered" if this is what you looking for.
Rasika
**** Pls rate all useful responses ******
Rasika Nayanajith
Rasika
Wonderful, thanks. I was clicking on the building and then looking for the action.
PERI_Admin
I cannot find this feature in Prime Infrastructure 3.7
Was this feature removed in Site Maps (New)?
Go into the old map system and look at the Hierarchy. You can move the building from one site to a different one using the drop down commands at the top. Check which building and select move buildings then it is like the process described above.
Brian
