Reset CAPWAP session on AP from controller
Wes Schochet
Level 7
Level 7
Hi All-
In the 9800 GUI Access Point configuration page, on the Advanced tab, there is a button to "Reset CAPWAP connection to AP without reboot".  Is there a 9800 CLI command that will do this as well?    I know I can do it from the AP CLI, but I am trying to figure out how to do this from the controller.
Thanks!
balaji.bandi
ap name <AP_NAME> reset capwap - It immediately terminates the current CAPWAP tunnel between the controller and the specific AP
clear ap config <AP_NAME> keep-ip-config -  Clears AP-specific settings while preserving the static IP, effectively forcing a clean re-join
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/99763-reset-lwappconfig-lap.html
BB
balaji.bandi
BB
Thanks!
