Reset to factory default doesn't work on 1142 AP
Adrian Mihailov
Dear All,
We have an AIR-LAP1142N-E-K9  deployed in a H-REAP setup.
This AP already got the configuration from the WLC when it was deployed at a remote site.
Now we moved it to another site, but it doesn't appear in the WCS and i don't see any CAPWAP debug messages on the WLC.
The routing work fine between the AP and the WLC, the AP also gets an IP address from DHCP and also received Option 43 information.
Now my guess was that the AP doesn't associate with the WLC because it has the old config file and it runs in local mode(without trying to connect to the WLC).
We want to reset to factory defaults because we want to delete the configuration and force the AP to get a new config from the WCS.
I don't know the enable password so i had to use other methods for reseting to factory defaults.
I tried to use the information from here:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_21a_JA1/configuration/guide/scg12421aJA1-chap22-trouble.html#wp1058433
I used the "MODE button":
I get the following message from the console:
"button pressed for 5 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
But after the reboot the config is not reset, because the AP still has the same hostname and i also get error messages when the AP reads the configuration:
ip ssh version 2
% Invalid input detected at '^' marker.
transport input ssh
aaa new-model
Next thing i tried was to use the CLI and to delete the config files from the boot loader mode.
But in this case, after reaching the "ap:" prompt and entering the "dir flash:" command, i don't see the file name "config.text".
This file should hold the config and it should be renamed, but how can i rename it if it's not there ?
Can someone tell me a working procedure on how to reset the AP to factory defaults?
You can see attached a log from Putty, after i used the MODE button to delete the config.
Thanks in advance,
Adrian
Did you ever get an answer for this?  Regardless, I believe what you're looking for is
ap: delete flash:private-multiple-fs
Are you sure you want to delete "flash:private-multiple-fs" (y/n)?y
File "flash:private-multiple-fs" deleted
That is the actual private config file.  Without it, the AP should boot up with factory defaults.
-Rob
27 Replies 27
Surendra BG
I request you to hold the mode button for 10 seconds and at the time the device comes up, issue the command  clear lwapp private-config
if you want to prime this AP to a controller then..
AP#lwapp/capwap ap ip address
AP#lwapp/capwap ap ip default-gateway
AP#lwapp/capwap ap controller ip address
Surendra
Surendra BG
clear capwap private-config
Surendra BG
I would try that, problem is that i don't have the enable password on the AP.
Do i get into the enable mode directly if i keep the button pressed for 10 seconds?
No issues... nothing will hapen if we keep on holding the mode button for 10 seconds.. and make sure not more than that.. it may go toi rommon.
>> We need to issue the command "clear capwap privat-config" then the telnet, enable password will be Cisco... username will be cisco.
Surendra BG
Is there any way to clear the Lwapp config from ROMMON?
I tried yesterday to use the "Cisco" as the enable password, but it didn't work.
I will try also today, and i will capture the complete logs from Putty.
I tried that reset procedure, with the MODE button pressed for 10 seconds, but it doesn't work.
The enable password is not reset, i tried "Cisco" but it doesn't work.
I receive the following message after releasing the button:
button pressed for 9 seconds
Then after the AP boots, i try to enter into enable mode, but the "Cisco" password doesn't work.
Password:
Password:
% Bad secrets
How can this AP be reset to factory defaults from ROMMON?
I can reach the "ap: " prompt, but what do i need to do there?
try reboting the AP again and lets see if we could get the AP out from the AP: mode (Rommon mode).
If we are not able to then we need t ofollow the below steps..
Using the CLI
Follow the steps below to reload the access point image using the CLI. When the access point begins to boot, you interrupt the boot process and use boot loader commands to load an image from a TFTP server to replace the image in the access point.
Note Your access point configuration is not changed when using the CLI to reload the image file.
Step 1 Open the CLI using a Telnet session or a connection to the access point console port.
Step 2 Reboot the access point by removing power and reapplying power.
Step 3 Let the access point boot until it begins to inflate the image. When you see these lines on the CLI, press Esc:
Loading "flash:/c1100-k9w8-mx.v122_13_ja.20031010/c350-k9w7-mx.v122_13_ja.20031010"
Step 4 When the ap: command prompt appears, enter the set command to assign an IP address, subnet mask, and default gateway to the access point.
Note You must use upper-case characters when you enter the IP-ADDR, NETMASK, and DEFAULT_ROUTER options with the set command.
Your entries might look like this example:
ap: set IP_ADDR 192.168.133.160
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.133.1
Step 5 Enter the tftp_init command to prepare the access point for TFTP.
ap: tftp_init
Step 6 Enter the tar command to load and inflate the new image from your TFTP server. The command must include this information:
•the -xtract option, which inflates the image when it is loaded
•the IP address of your TFTP server
•the directory on the TFTP server that contains the image
•the name of the image
•the destination for the image (the access point Flash)
Your entry might look like this example:
ap: tar -xtract tftp://192.168.130.222/images/c1100-k9w8-tar.122-13.JA1 flash:
Step 7 When the display becomes full the CLI pauses and displays --MORE--. Press the spacebar to continue.
extracting info (229 bytes)
If you do not press the spacebar to continue, the process eventually times out and the access point stops inflating the image.
Step 8 Enter the set BOOT command to designate the new image as the image that the access point uses when it reboots. The access point creates a directory for the image that has the same name as the image, and you must include the directory in the command. Your entry might look like this example:
ap: set BOOT flash:/c1100-k9w7-mx.122-13.JA1/c350-k9w7-mx.122-13.JA1
Step 9 Enter the set command to check your bootloader entries.
ap: set
BOOT=flash:/c1100-k9w8-mx.122-13.JA1/c350-k9w7-mx.122-13.JA1
DEFAULT_ROUTER=192.168.133.1
IP_ADDR=192.168.133.160
NETMASK=255.255.255.0
Step 10 Enter the boot command to reboot the access point. When the access point reboots, it loads the new image.
ap: boot
>> the default password is Cisco or cisco
Surendra BG
I can get out of the ROMMON mode, that's not the problem.
Problem is that the config file is not reset to factory defaults.
After the reboot you can see that it uses the old config file.
It has the hostname "BEDESAP8" which was the old hostname.
Also the enable password isn't changed to Cisco.
BEDESAP8>sh capwap client config
configMagicMark         0xF1E2D3C4
chkSumV2                17413
chkSumV1                40163
swVer                   3.0.51.0
adminState              ADMIN_ENABLED(1)
name                    BEDESAP8
location                BE - Dessel
Where is the config file stored?
After i issue the dir flash: i don't see the "config.text" that i should rename.
I tried renaming the lwapp_reap.cfg file, but it still has the old config.
ap: dir flash:
Directory of flash:/
2    -rwx  8455                     event.log
4    -rwx  23940                    lwapp_reap.old
5    drwx  128                      c1140-rcvk9w8-mx
8    drwx  192                      c1140-k9w8-mx.124-18a.JA2
12   -rwx  6168                     private-multiple-fs
13   -rwx  170                      env_vars
I would delete the firmware (c1140-k9w8-mx.124-18a.JA2) making sure to leave the recovery image (c1140-rcvk9w8-mx).  After a reboot, the AP should boot to the recovery image and try to join a controller using whatever discovery method you have in place.
-John
After the reset to factory defaults, the AP boots with the /c1140-rcvk9w8-mx image, as you can see below.
Problem is, the configuration isn't deleted.
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...#############################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
Someone from Cisco, can you tell me where the config file is, and how can i delete it if i don't have the "enable" password?
Thanks in advance,
Adrian
-Rob
No, i haven't received a response that works for my case.
I had to send the AP back to the site from where it got his configs and reset it from the WCS.
I'll note your solution and i'll test it the next time i encounter an issue like this one.
Adrian
I tried this command, delete flash:private-multiple-fs, but it didn't work me. Any idea why?
Here's the flash contents after running the command and reloading
    2  -rwx           5  Feb 28 2002 22:49:36 -06:00  private-config
    4  -rwx         289  Feb 28 2002 18:00:11 -06:00  env_vars
    6  -rwx        2043  Feb 28 2002 22:49:36 -06:00  config.txt
    7  drwx         256  Feb 28 2002 18:18:05 -06:00  c1140-k9w7-mx.124-21a.JA1
I don't want to delete anything else without knowing if I'm deleteing the correct file.
There has got to be a way to delete the startup config.
so I took a shot at it and deleted private-config and that didn't do it, so then I deleted config.txt and finally back to defaults.
