Restrict specific users in ISE for a specific SSID to only one web sit
ignacionovick
Hi:
  I need to know if there is any way to restrict a specific set of users in ISE that conects to a Guest WiFi to access only one web portal. I have a 9800 WLC with version and ISE with version 2.4.0.357.
Thanks in advance!
Regards.
Mark Elsen
 - Check this document : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213920-central-web-authentication-cwa-on-cata.html , the authorization profile on ISE for a user group can contain an URL (e.g.) , amongst other parameters ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
as mentioned other post, you need to do different ways, but best some user source based on AD or Local Groups you can restrict with profiles.
BB
