Restrict WLAN Access based on SSID with WLC and Cisco Secure ACS Configurat
Hi there,
Is there any solution to restrict wlan based access based on ssid using layer 3 (web authentication)?
sample in this link: http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a00807669af.shtml
uses only layer 2.
5 Replies 5
Rob Huffman
Hi Dave,
I couldn't find the link you provided :(
Have a look at this example, it sounds like what you are looking for;
Dynamic VLAN Assignment with RADIUS Server and Wireless LAN Controller Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
Hope this helps!
Rob
Hi Rob,
This is the link:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807669af.shtml
Examples here are working in Layer 2 authentication method, but I need a solution in Layer 3 authentication method like Web Authentication.
hi David,
  Did you manage to find a solution for this ? I have a similar requirement for using DNIS filtering for webauthentication and it doesnt seem to work.
regards
Joe
Joe:
With webauth it does not work by default because the wlc does not send the ssid name in called-station-id attribute.
You need to configure
he wlc to send the ssid along with the ap mac address n that attribute.
Use this command on wlc cli:
config radius callStationIdType {ip_address, mac_address, ap_mac_address, ap_macaddr_ssid}
Use the last option: ap_macaddr_ssid
Hope this helps.
Amjad
Rating useful replies is more useful than saying "Thank you"
Stephen Rodriguez
It sounds like you are looking for NAR.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_tech_note09186a0080858d3c.shtml
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
