Rouge access point info not showing up in NCS
eajackson
The rouge access points being detected by the 5508 WLC are not showing up on the Context Aware tab of NCS? I have a MSE 3310 installed and configured and it shows to be syncronizing with the WLC. I'm sure I am missing some part of the configuration just not sure where. Any help is appreciated.
5508 WLC - v7.2.103.0
MSE 3310 - v7.2.103.0
Cisco Prime NCS - v1.1.1.24
Amjad Abdullah
I think rogue aps should appear under security tab. Right?
Rating useful replies is more useful than saying "Thank you"
They do show up under the security tab but I was thinking that they would be detected by the MSE as well?
They should show up in  the MSE,
I on different but related note ,  have aissue where Cisco APs (autonomous) are not being detected in NCS as rogue APs, they are 1240s and 1130s . On NCS 1.1.058 and WLC are 7.2.110.0 MSE is the same 7.2.110. 0. The site has all 3600 APs
