Securely Connect two BR1310 Bridges
Markus Pethe
Did anyone of you found an Configuration Example for an secure Connection between two 1310 Bridges.
jdewberr
try this for WPA-PSK:
***global config for both bridges***
dot11 ssid cisco
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii 0 1234567890
**Root bridge config (only showing the relevant part of config)**
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid cisco
NON-ROOT config****
no ip address
no ip route-cache
ssid cisco
joe
WPA-PSK is vulnerable against dictionary attacks, ideally use a
random hex string as PSK. (I guess "1234567890" was just an example)
Since you are using 1310 on both sides, I'd suggest using AES (WPA2)
for encryption. Simply replace
with
encryption mode ciphers aes-ccm
The only disadvantage is the missing "concatenation" support if AES is enabled.
Thanks for your replys!
I also added this:
*dot11 ssid
#max-associations 1 ! So after the other bridge is associated no more would be allowed (I hope)
I also tried to apply the filter
*dot11 radio 0
#l2-filter block-arp
But when I do this on both sides (root and non-root) I lose the association.
did you ever get WPA2 encryption to work between the 2 cisco 1310 bridges ?
