Selecting an outdoor wireless access point
kumaraw84
I have been looking for an autonomous wireless access point for a new deployment.
Can someone recommend one for me ?
I checked the APs on the following URL but could not determine which one to select.
http://www.cisco.com/en/US/products/hw/wireless/products_category_buyers_guide.html#~outdoor
To summarize, following are my requirements
  • outdoor
  • autonomous
  • directional
  • Internal antenna preferred
  • should be able to use for a point to point wireless link
We were using 1310 APs previously but they are end of sale now.
Thanks.
6 Replies 6
Scott Fella
Cisco resells the exalt r5005 bridges which replaced all their point to point bridges.
-Scott
vlad.mihailov
If it has to be outdoor there is nothing really but the 1552 and those are not autonomous (ie you will need a controller)
Check options to house APs inside of a shelter and, perhaps, get antennas out. May work for you..
Thanks both for your responses.
Does it mean that CISCO does not have a replacement for 1310 autonomous outdoor access points ?
( except for exalt products )
I must have an autonomous outdoor access point to implement the point to point wireless link
Charlie Moreton
You can put the Autonomous IOS on a 1552 and run that way.  You'll need a CCO login, but you can download this file listed under the 1552 for autonomous deployments:
c1520-k9w7-tar.152-4.JA1.tar
Scott Fella
I think the Exalt r5005 will be cheaper than two 1550's. Any point to point, you would rather use a true bridge product.
-Scott
Agreed.
