SFP port configuration on switch
petercinvest
I have two SFP port on my layer 2 switch and I want to connect to my WLC 5508. is there any specific setting required compared to normal gigabit interface port?
so I just simply setup trunk in the SFP port, is it enough? thanks
6 Replies 6
Scott Fella
That is really the basic way to do it.  Take a look at some guides for reference.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/68100-wlan-controllers-vlans.html#configs
-Scott
-Scott
The link is quite ok, but my question is whether any specific configuration required in SFP port compared with normal trunk port?
also any command to list the SFP port  and POE port in my layer 3 switch.
if my switch don't have SFP port, can I connect SFP port from WLC and non-SFP port in my core switch? thanks
No special configuration because it comes up as a normal port.  The WLC can connect to any port as long as it's a gigabit port.  Commands for your switch you will have to look at your switch configuration guide.
-Scott
-Scott
I use service port to connect to WLC, how do I export WLC configuarion file to my laptop instead of tftp?
All the info can be found in the configuration guide
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70mfw.html#pgfId-1063850
-Scott
-Scott
