signal vs datarate
muhsi_2015
In what situation  client is downshifting the rate  after a retry happened in higher rate  and even  in lower data rate  its retrying  ?.
Is it  ok  an ipad mini using 24Mbps , Does it can go an higher data rate ?
Philip D'Ath
If the client has selected to go with a lower rate then you would need to speak with the vendor of that client to find out what algorithm they use.
Refer below post as it gives you an idea how this work
https://mrncciew.com/2014/11/03/cwap-dynamic-rate-selection/
Rasika
*** Pls rate all useful responses ***
If there is a power mismatch between the station and the access point then station downshift the rate ?
Thank you
I would say RSSI/SNR or packet retry could lead into downshift rates.
Even AP & Client power mismatch situations resulting retransmissions, so eventually client will try downshift rates.
Refer this 5min video
https://www.youtube.com/watch?v=jxeQufY2HpQ
Rasika
