SSC AP with H-reap enable WLAN
Foo Chuan Soon
We have a ssc ap that couldn't use H-reap mode, and all other ap already in H-reap. The Wlan we configured for enable H-REAP Local Switching and Learn Client IP Address, the problem is when user connected to this ssc ap, they will have intermittent issue, not able to connect to LAN or WAN for a while then wait another few minutes, no more issue. It is because of the H-reap or ssc ap issue?
17 Replies 17
Not sure need to monitor for 1 day to see if it is AP issue or WLC.
the logs are very clear telling the channel was changed on the AP this is the reason!!
Surendra
Surendra BG
grabonlee
Level 4
Level 4
I would suggest that you do a CLI session to the controller, do a show msglog and search for the particular time that the reset occurred to see a reason for the reset. Most likely you will see a series of messages such as:
Cannot find 802.11g channel
Controller issued reset to AP mac: xxxx:xxxx:xxxx:xxxx
If this is so, I would suggest that you upgrade your WLC software as it may have bugs.
Hope this helps.
