Upgrade Cisco Embedded Wireless Controller on Catalyst Access Points
andrea.soc
Visitor
i have a problem with upgrade my new Catalyst 9120AXI-E to the latest version of software of the Cisco Embedded Wireless Controller on Catalyst Access Points 17.6.4
I donwloaed this
https://software.cisco.com/download/home/286322988/type/286323077/release/17.9.3
i extracted it to my tftp server
from web UI i launched software management --> Software upgrade --> Tftp etc..
but receive an error
Failed to Fetch Controller Image Version File to EWC
thanks!
balaji.bandi
So your EWC is Cat9K AP - you try to upgrade from TFTP it is failing  is it ?
is the TFTP Server reachable and have the File ?
try from command level and check
# show wireless ewc-ap predownload status
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/16-12/config-guide/ewc_cg_16_12/image_download.html#id_128455
BB
andrea.soc
Visitor
Yes
Yes
this is the error!
andrea.soc
Visitor
WLC-9100#show wireless ewc-ap predownload status
Predownload Status: Controller Image Download Failed
Predownload Error: Failed to Fetch Controller Image Version File to EWC
never seen this issue on WLC controllers. If you seeing this issue :
check below thread for different approach :
https://community.cisco.com/t5/wireless/c9130axi-ewc-cli-software-update-predownload-error/td-p/4507805
BB
