07-01-2015 10:23 AM - edited 07-05-2021 03:29 AM
Hi! I'm configuring for the first time an access point Aironet 702. The problem is that I need to create a user to have certain acccess. To be precise I need the user to change only the SSID password.
I've been trying do it through user levels but got no success. Also, the user created with level added through CLI can't log in with the same credentials to the web interface.
Any ideas?
08-18-2015 08:05 AM
I don't believe that there is an access level that will allow only the PSK for an SSID, the access levels on the access points are not that specific. In regards to your comment about the user & password difference between the CLI/Telnet/SSH and Web GUI, you need to enable aaa authentication on the access point and set it to use the local database, then you will be able to use those accounts to login via the GUI.
This guide may help
08-25-2015 06:06 AM
are you using local/radius server for authentication. If Radius (ISE) then you can achieve this and definitely not by access levels
