Using an AIR-LAP 1024N as a TEST AP
Minger_Magnet
as the subjects states I would like to use the abovementioned AP as a test AP for wireless surveys. I want to do this without the need for using a switch to stop the unit rebooting.
I believe that I need to enable thick mode? or would that be Autonomous mode - which would require me to change from LWAPP - IOS?
What is the best way for me to configure the AP so that it broadcasts the given SSID and not continually reboot?
Thanks in Advance
Jez
10 Replies 10
Surendra BG
Go for Autonomous mode and configure a SSID and u will be good to go!! the AP will not reboot.
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Thanks Surenda , I will give this a whirl on Friday when I receive the injector.
Sure!! Lemme know if u need any kinda assistance..
Surendra
Surendra BG
Thank You very much. I may take you up on that offer.
I have managed to sort this by using a different comman for the IP addressing
lwapp ap ip address
Thanks for the help fellas.
Could you please let me know the script for enabling Autonomous mode?
I followed your instructions here
https://supportforums.cisco.com/thread/2060925
But found that I got some errors on some of the lines below
               Ap(config)#int fa 0
Invalid input detected at '^' marker.
Ap(config-if)ip address
AP44d3.cab0.7ad3(config)#no shut
Thanks in advance
Jez
Surendra,
I now have my AP in autonomous mode.
We will be purchasing a few more but will be buying them ap AIR-AP's so that we don't have to re-image the AP's.
1 issue I now have after re-imaging from :
c1140-rcvk9w8-mx/c1140-rcvk9w8-mx
To:
1140-k9w7-mx.124-25d.JA/c1140-k9w7-mx.124-25d.JA
The CLI commands for setting IP - MASK etc have changed. I know I can use GUI after but I would like to document a process of how to from opening the box.
Appreciate your help?
Jez
Get the console access and assign the IP address to the BVI interface of the AP.. here is the getting started guide..
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_21a_JA1/configuration/guide/scg12421aJA1-chap4-first.html
Please lemme know if this answered ur question!!
Surendra
Surendra BG
thomas03usmcsf
It is important to remember to always do surveys with the same model of access point that will be deployed, if possible.
Thanks Thomas,
This is the exact same model we will be deploying on the project we are working on.
