Does anyone know if it is possible to use 1 WLSE to manage 2 (or more) completely independant Cisco WLAN deployments? Each deployment would be using it's own ACS (RADIUS), WDS, etc... WLSE is the only common piece in both.
When entering the WLCCP credentials in WLSE, there is only 1 Radius U/P field. What happens if the WLSE U/P is different on each deployment? Would making the U/P the same on each deployment be a work around?
I have successfully loaded 2 WDS Server APs in WLSE but they both share the same RADIUS for Authentication. If they each had their own RADIUS server but the same WLSE U/P existed on both, would it work?
Serge
