10-11-2020 10:26 PM - edited 07-05-2021 12:38 PM
Hello Experts,
Is there any means to get the power that an Access Point is drawing from the switch?
Rather than Full power if there are means to obtain the exact power that would serve my purpose.
Running into a situation wherein IW3700 as light weight and autonomous APs are drawing power from an IE1000 switch.
While they operate as expected with their radios up and so i assume they get full power but when verified from switch it says the power delivered is only 7.5 watts- which certainly may not be the case for a fully operational AP.
So wanting the see the option of exact power consumed on an AP rather than just reflection of 'Full Power'
10-11-2020 11:18 PM
Check the AP Data Sheet.
10-12-2020 01:54 AM
Hi Leo,
Thank for your reply.
The concern here is not on the power that an AP would require, rather the query is the power that an AP is currently drawing from the switch.
In my case the switch says it provides 7.5 Watts, which certainly is not the case as with 7.5 watts even the AP radio will not come up.
So i am looking for means to obtain the power drawn by an Access Point while in operation.
10-12-2020 04:23 AM
The AP does not have a USB port so power drawn and power required are the same.
10-12-2020 05:44 AM
10-12-2020 01:40 PM
You can use #debug ilpower cdp from the switch and that will show you the power consumption for that AP port
Also, use this doc as a reference: Troubleshooting Power over Ethernet (PoE)
