vlan assignment using radius for aironet 1200
g.peart
using Funk radius server and MD-5 challenge I can
assign users to a vlan on my switches. But when I try
to assign vlans to users on AP via the radius server
it fails. All SSID are mapped to vlans and encryption
for all is WPA/TKIP. The authentication still works
and I've sucessfully used eap-ttls,PEAP,EAP-TTLS
all against a microsoft AD.
Anyone using radius to assign vlans or SSID with success ?
Also the users must enter an SSID before they can connect to AP, would this stop vlan assignment ?
IOS ver 12.3(2)JA,
11 Replies 11
m-niemi
Cisco Wireless Virtual LAN Deployment Guide says that there are 3 IETF Attributes that should be enabled for assigning ssid/vlan for user.
Also there are problems with 12.3(2)JA and at least for me 12.3(2)JA2 is working better.
http://www.cisco.com/en/US/customer/products/hw/wireless/ps4570/prod_technical_reference09186a00801444a1.html
I upgraded to 12.3(2)JA but no luck,I can see
from the logs that AP is looking for vlan/ssid attributes. I know form my 2950 I needed the line
"aaa authorization network default group radius"
for md5 and have same line in AP config.
Does anyone have dynamic assignment via radius/EAP
for SSID/VLAN definetely working or should I give up ?
I have this working with Cisco Secure ACS. At one time I also had it working with Microsoft IAS on windows 2000 server.
When my students login, they are assigned a specific VLAN through radius. When Fac/staff login, they are assigned a different VLAN through Radius.
I have not used Funk, but I do know it works with ACS and IAS.
Here is an older link concerning vlans and wireless. It also includes the correct radius attributes that need to be used...they are -
IETF 64 (Tunnel Type)—Set this to VLAN
IETF 65 (Tunnel Medium Type)—Set this to 802
IETF 81 (Tunnel Private Group ID)—Set this to VLAN ID
This link is kinda old since it uses the Vxworks GUI, but has some good info..
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgch4.htm
Here is another link for the latest software...
http://www.cisco.com/en/US/customer/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a0080341d34.html
If the links don't work, I did a search on Cisco.com for vlans and wireless..
Don Hickey
Don,
You say you have this working with IAS? Did you use cisco-avpair attributes? Or the standard ones with microsoft. Im thinking my setup isnt working because the cisco switch doesnt understand the attributes being sent by the IAS.
Cheers in advance.
What attributes, and what specific values are you sending to the AP?
Im in a wired situation.. not sending any attributes to an AP. Im sending attributes to a 3560 cisco switch. But the principles are kind of the same.
The attributes i am using are
cisco-avpair = "tunnel-type(#64)=VLAN(13)",
cisco-avpair = "tunnel-medium-type(#65)=802 media(6)"
cisco-avpair = "tunnel-private-group-ID(#81)=SALES"
Cheers.
Guys,
I am running ACS, but I took a look at my IAS settings I had running before we purchased ACS..
These are from Windows 2003 Server
Tunnel-Medium-Type - 802
Tunnel-Pvt-Group-ID - 31 <--- Vlan #
Tunnel-Type - VLANS
Tunnel-Tag - 10 <- I can't remember why we needed this, but if you search these archives it is in some of my previous posts (over 1 yr ago).
Framed Protocol - PPP
Service-Type - Framed
I did not use the cisco-av pairs...
These are Radius Standard..
Don
hi,
what do i have to config the interface in switch which access point connected with? perhaps trunking?
g.peart
thanks for all the input, it seems the problem was with
Funk radius server, since peap/eap-ttls are tunneled
you have to create filters to on the server so that it sends the attributes through the tunnel to the AP.
Everything now works great.
Very interesting to know that Wireless LAN can support dynamic VLAN membership..
Does this mean that one SSID will get mapped to different wired VLAN, based on user authentication..?
I am also interested to know if this is also supported on LWAPP/WlAN CONtroller based deployments? Any success stories there..?
Hi, the airespace controller does support dynamic VLAN assignment but I don't know how to deploy it,sitll looking for configuration example
