VLAN Setup on Catalyst APs with EWC and Vlans routed by switch
jeremy0463
I have a Catalyst 9200L and three Catalyst 9115 access points with EWC. I iam trying to understand SSID to Vlan setup when the vlans are routed on the switch and the port connected to the AP is a trunk prot with the management port as native.
I have used 2504 WLC and 1852 APs before with vlan switching handled by the layer3 switch (trunk port on the switch, managment vlan native, additonal vlans tagged>>>connected to port on 2504 with interfaces defined in each vlan, and each wlan set to that particular interface.) That works great. As I understand it, the APs create a capwap tunnel over the management vlan (each ap is connected to an access port on that vlan), then the vlans fron the switch are trunked to the WLC and the WLC handles the routing to the particular interface.
But EWC seems very different. Since there is no controller appliance on this network, and with the same switch configuration essentially (trunk port with routing handled on the layer3 switch), what is the best way to route wlans to vlans? Ii have a test wlan setup with policy and tag both setup and i have wireless access to the managment vlan. Policies only let me add one vlan per AP.
Please help.
34 Replies 34
Rich R
- Does the ewc itself handles Vlan routing between wlans instead of it going back to the switch?
No.  The EWC management (on native VLAN) is purely for your SSH/https management access to the EWC and the AP CAPWAP control connection to the EWC WLC.  No client data is switched by the EWC at all.  It is simply bridged/dumped onto the trunked VLAN on the switchport by the AP.
- Can the vlans on the EWC match the vlans on the switch or will that conflict?
They must match or it won't work - the VLAN you configure for each WLAN is what the client traffic will be tagged with on the switchport
- Will traffic between wlan flex connect Vlan and wired Vlan on the 9200 be on the same broadcast domain essentially?
Yes
- can the 9200 still handle the dhcp, acls, etc instead of the ap?
The AP cannot handle it so the 9200 must handle it.
- how does the traffic actually route from the wireless client back on one Vlan to the switch and then to a wireless client on another Vlan if the 9200 handles the routing? In other words, how does flex connect work differently than the 2504 or a 9800 wlc with standard trunk ports in terms of the traffic.
Flex on 9800/EWC/2504 is all the same.  Central switching tunnels client traffic to the WLC over CAPWAP and the WLC bridges it to VLANs connected to the WLC switch port.  With flexconnect local switching all client traffic is simply bridged directly to the VLAN on the AP port, no different to traffic coming from a hardwired client on that VLAN.
-Now my struggle point is assigning particular VLANs in the flex profile to particular WLANs. What am I missing?
That is done is the "wireless profile policy" using the VLAN(s) you defined in the flex profile.  You can just enter the VLAN number/ID, not necessary to use the name.
-I would not need a flex profile in that case then right?
The Flex profile is used to define the VLANs the AP must use and give them names.  You can then use those VLANs for the WLANs.
So then Rich, for the flexconnect configuration, I need to create a wlan profile for each ssid, then a policy profile for each vlan with that vlan assigned in the policy profile, then a policy tag that maps each wlan profile to each of those policy profiles, then each assigned vlan also added to a single flex profile, right?
Yes but not clear what you mean by "then each assigned vlan also added to a single flex profile, right?":
The VLANs for the SSIDs are defined in the flex profile for the AP - a bit like you define VLANs for a router or switch to use.
Have a read through these:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213911-understand-catalyst-9800-wireless-contro.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/newconfigmodel/b_catalyst-9800-configuration-model.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213945-understand-flexconnect-on-9800-wireless.html
https://mrncciew.com/2023/01/21/9800-flexconnect-basics/
That is where all of this gets confusing. I don't have a 9800 in place, only the EWC. Most of the documentation for flex connect assumes there is a remote appliance. The only EWC configuration example (https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/white-paper-c11-743398.html) is really vague on the flex connect part and does not explain how the flexconnect profile relates to the policy profile. I only understood the need for one policy profile for each vlan based on Scotts picture above. Here are some screenshots of what I meant above:
Screenshot 2023-12-04 at 5.23.19 AM.pngScreenshot 2023-12-04 at 5.25.22 AM.pngScreenshot 2023-12-04 at 5.25.31 AM.pngScreenshot 2023-12-04 at 5.26.53 AM.pngScreenshot 2023-12-04 at 5.27.05 AM.pngScreenshot 2023-12-04 at 5.28.22 AM.pngScreenshot 2023-12-04 at 5.29.58 AM.pngScreenshot 2023-12-04 at 5.30.10 AM.png
Then I would tag the aps with those profiles. Am I missing anything?
      >...Most of the documentation for flex connect assumes there is a remote appliance
                     Since you only do flexconnect the principles remain the same.
                         >...Then I would tag the aps with those profiles. Am I missing anything?
    Not really try it out ; verify  controller configuration afterwards with CLI command show tech wireless ; feed the output into
        Wireless Config Analyzer
         Not convinced ? ; checkout This is so good
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Yes when reading the general 9800 guides you just have to remember anything applying to central switching (user traffic switched by WLC) is not relevant in the EWC context because it only supports flex local switching which means all the EWC does is configure the AP.
Ro rich, does my configuration look good above? I am really struggling getting this thing working. When I first boot it up, clients connect, but then they just drop out of no where, and eventually, connections try to connect and fail. When they do connect, they are in the proper vlan and they have an IP in the DHCP range for that vlan (switch is handling the DHCP). Just frustrating. I defaulted and am reconfiguring. I will post a config for both the EWC and the 9200 switch when I am finished if it fails again so that you guys can take a look. I have done everything major that the Wireless Config Analyzer says to do.
To be honest I do almost everything on CLI so I haven't looked over your config specifically.  I just find it easier to read a few lines of text instead of trying to decipher screenshots <smile>
Maybe post the "show run" config when you're finished configuring along with "show ap tag summ" and "sh wireless client mac-address <aaaa.bbbb.cccc> detail" for one of the connected clients.
I'm learning CLI slowly but surely. I will send you all those things tonight when I get home. Thanks so much!
Here are the CLI outputs Rich:
EMBEDED WIRELESS CONTROLLER
Wed Dec 06 2023 20:02:56 GMT-0600 (Central Standard Time)
#show run
Building configuration...
Current configuration : 13209 bytes
! Last configuration change at 22:34:47 UTC Tue Dec 5 2023 by admin
! NVRAM config last updated at 06:17:33 UTC Wed Dec 6 2023 by admin
version 16.12
no service pad
service password-encryption
service call-home
no platform punt-keepalive disable-kernel-core
no platform punt-keepalive settings
platform console serial
hostname WLAN_Controller
boot-start-marker
boot-end-marker
enable secret 9
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone UTC -6 0
no fips authorization-key
call-home
 ! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr sch-smart-licensing@cisco.com
 profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
ip name-server 208.67.222.222 208.67.220.220
login on-success log
flow exporter default-flow-exporter
 destination local wlc
flow monitor default-flow-monitor
 record wireless avc basic
access-session mac-move deny
password encryption aes
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
crypto pki trustpoint TP-self-signed-3395605568
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3395605568
 revocation-check none
 rsakeypair TP-self-signed-3395605568
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01
  30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
  32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
  6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
  3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
  43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
  526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
  82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
  CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
  1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
  4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
  7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
  68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
  C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
  C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
  DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
  06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
  4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
  03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
  604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
  D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
  467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
  7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
  5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
  80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
  418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
  D697DF7F 28
  quit
crypto pki certificate chain TP-self-signed-3395605568
 certificate self-signed 01
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33333935 36303535 3638301E 170D3231 31313037 30303034
  33355A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33393536
  30353536 38308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100A7BA DB3AA54D 76E6A250 501F264E 75071E3F 541FEFAB E944FEE0
  1FF1848E A58820B6 6F257AF6 7C39C19F 5EAFE2D0 27741BD5 20EFFD14 12A148E0
  66A06F3D 3AF7DA27 BF29C94C 5FE7E0FA 43FC7EAD 949CDC53 9BCC9210 12362A1F
  671D6E33 45B284E0 7F73949E 1F748894 39C07EAD 239B75A0 221455C6 3E0E02D6
  CF2ECC4A ACD6E75C BE42F593 DD34F09A 53180904 80C43A79 3DFC8FB5 FDEA6B1B
  813E3A31 1010A53D C28BE646 84F02F4F 9D6D9D23 A13369A5 A6AEDD3C B5699459
  DA433562 74992C99 AE9889AF B91EAC09 679C7866 189D16D9 E74E728B 7910FD1C
  1D570791 89F26FFA 9CA19395 9CCB956C B6A58122 21D3187F 1C496F13 EE7512F0
  F0EFFED7 2E170203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 1425DC21 45CE6974 80E6E0E2 35B3ACE3 9D18D5D0
  1A301D06 03551D0E 04160414 25DC2145 CE697480 E6E0E235 B3ACE39D 18D5D01A
  300D0609 2A864886 F70D0101 05050003 82010100 75833A82 91DCFF27 51981D0A
  17E455DE 3C345301 0378BCA6 F5CF1CAA 496102BC 8DE4BE55 E20F6921 AF9EADFE
  255D8BCE B4F18DE3 48A1BE68 4AB54420 79CC821B 1910E145 5AB0B177 44B648C0
  7D56A5DC 2D6EF14A C4022F66 439F4C24 0BC37988 A01BE979 9C9E7D97 A9AEA806
  0CF79277 44EBFEBA 677E22AC EEC23F69 E9211291 44CB3F4D 5EBB196B 763AAA17
  1E5D96B0 FFD172B8 BBEF540A A0DE9C50 34EE8D97 6D080D56 44D58578 65827598
  1C0AE165 96AE9925 71054D0F 384E104A 445B3B17 8BEED3BA C86DCD86 61024ECA
  81FE5F73 C960C0F3 92CAB660 7BFB3F17 3F521EF7 6433C02A C997B930 2B83C014
  FBD2AD7E 84D6D0C5 805F4D01 0E686E1C 78F11571
  quit
crypto pki certificate pool
 cabundle nvram:ios_core.p7b
service-template webauth-global-inactive
 inactivity-timer 3600
service-template DEFAULT_LINKSEC_POLICY_MUST_SECURE
 linksec policy must-secure
service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
 linksec policy should-secure
service-template DEFAULT_CRITICAL_VOICE_TEMPLATE
 voice vlan
service-template DEFAULT_CRITICAL_DATA_TEMPLATE
memory free low-watermark processor 33020
license udi pid C9800-AP sn
device classifier
username admin privilege 15 secret 9
redundancy
 mode sso
interface GigabitEthernet0
 description Management Interface
 mac-address 0000.5e00.0101
 ip dhcp client client-id GigabitEthernet0
 ip dhcp client broadcast-flag clear
 ip address 192.168.10.30 255.255.255.0
 no negotiation auto
ip http server
ip http authentication local
ip http secure-server
ip http secure-trustpoint CISCO_IDEVID_SUDI
ip http client source-interface GigabitEthernet0
ip forward-protocol nd
ip tftp blocksize 8192
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 250
ip dns server
logging trap debugging
control-plane
banner exec ^C
#      Welcome to the Cisco Catalyst 9800-AP Embedded Wireless Controller command line interface.      #
# Please see command reference guide for the complete list of supported commands for this release:     #
# https://www.cisco.com/c/en/us/td/docs/wireless/embedded_wireless_controller_configuration_guide.html #
^C
banner login ^CWireless LAN Controller^C
line con 0
 exec-timeout 0 0
 stopbits 1
line vty 0
 length 0
 transport input ssh
line vty 1 4
 transport input ssh
line vty 5 15
 transport input ssh
line vty 16 50
ntp server 1.ciscome.pool.ntp.org
ntp server 0.ciscome.pool.ntp.org
ntp server 2.ciscome.pool.ntp.org
wireless aaa policy default-aaa-policy
wireless cts-sxp profile default-sxp-profile
no wireless ipv6 ra wired
wireless management interface GigabitEthernet0
wireless profile airtime-fairness default-atf-policy 0
wireless profile flex default-flex-profile
 description "default flex profile"
 native-vlan-id 10
wireless profile flex lewis-home-flex-profile
 description "Lewis Home Flex Profile"
 native-vlan-id 10
 vlan-name Users
  vlan-id 40
 vlan-name Guests
  vlan-id 50
wireless profile image-download default
 description "default image download profile"
wireless profile mesh default-mesh-profile
 description "default mesh profile"
wireless profile policy user-policy-profile
 autoqos mode fastlane
 no central association
 no central dhcp
 no central switching
 description "User Policy Profile"
 dhcp-tlv-caching
 no exclusionlist
 http-tlv-caching
 service-policy input platinum-up
 service-policy output platinum
 vlan 40
 no shutdown
wireless profile policy guest-policy-profule
 no central dhcp
 description "Guest Policy Profile"
 dhcp-tlv-caching
 no exclusionlist
 http-tlv-caching
 vlan 50
 no shutdown
wireless profile policy default-policy-profile
 no central dhcp
 description "default policy profile"
 http-tlv-caching
 ipv4 flow monitor default-flow-monitor input
 ipv4 flow monitor default-flow-monitor output
 vlan 10
 no shutdown
wireless tag site default-site-tag
 ap-profile lewis-home-ap-profile
 description "Lewis Home Site Tag"
 flex-profile lewis-home-flex-profile
 no local-site
wireless tag policy default-policy-tag
 description "default policy-tag"
wireless tag policy lewis-home-policy-tag
 description "Lewis Home Policy Tag"
 wlan "Lewis Home Guest" policy guest-policy-profule
 wlan "Lewis Home Wireless" policy user-policy-profile
wireless tag rf default-rf-tag
 description "default RF tag"
wireless tag rf lewis-home-rf-tag
 description "Lewis Home RF Tag"
wireless fabric control-plane default-control-plane
wlan "Lewis Home Guest" 2 "Lewis Home Guest Test"
 mdns-sd gateway
 security wpa psk set-key ascii 8 N`EMQ[ZifUTQ\VNNifJLB_[WdSZVBgAAB
 no security wpa akm dot1x
 security wpa akm psk
 wmm require
 no shutdown
wlan "Lewis Home Wireless" 1 "Lewis Home Wireless Test"
 mdns-sd gateway
 security wpa psk set-key ascii 8 HH]QOh\[cDH\EhDCV_DJSeNe[BOLUIAAB
 wmm require
 no shutdown
ap dot11 24ghz rf-profile Low_Client_Density_rf_24gh
 coverage data rssi threshold -90
 coverage level 2
 coverage voice rssi threshold -90
 description "pre configured Low Client Density rfprofile for 2.4gh radio"
 high-density rx-sop threshold low
 tx-power v1 threshold -65
 no shutdown
ap dot11 24ghz rf-profile High_Client_Density_rf_24gh
 description "pre configured High Client Density rfprofile for 2.4gh radio"
 high-density rx-sop threshold medium
 rate RATE_11M disable
 rate RATE_12M mandatory
 rate RATE_1M disable
 rate RATE_2M disable
 rate RATE_5_5M disable
 rate RATE_6M disable
 tx-power min 7
 no shutdown
ap dot11 24ghz rf-profile Typical_Client_Density_rf_24gh
 description "pre configured Typical Client Density rfprofile for 2.4gh radio"
 no shutdown
ap dot11 24ghz rrm channel cleanair-event
ap dot11 24ghz rrm channel cleanair-event rogue-contribution
ap dot11 24ghz edca-parameters fastlane
ap dot11 5ghz rf-profile Low_Client_Density_rf_5gh
 coverage level 2
 description "pre configured Low Client Density rfprofile for 5gh radio"
 tx-power v1 threshold -60
 no shutdown
ap dot11 5ghz rf-profile High_Client_Density_rf_5gh
 description "pre configured High Client Density rfprofile for 5gh radio"
 rate RATE_9M disable
 tx-power min 7
 no shutdown
ap dot11 5ghz rf-profile Typical_Client_Density_rf_5gh
 description "pre configured Typical Density rfprofile for 5gh radio"
 no shutdown
ap dot11 5ghz rrm channel cleanair-event
ap dot11 5ghz rrm channel cleanair-event rogue-contribution
ap dot11 5ghz edca-parameters fastlane
ap country US
ap tag-source-priority 2 source filter
ap tag-source-priority 3 source ap
ap location name Default_Location
 description Default_Location
ap profile default-ap-profile
 description "default ap profile"
 mgmtuser username admin password 8  secret 8
ap profile lewis-home-ap-profile
 description "Lewis Home AP Profile"
 hyperlocation ble-beacon 0
 hyperlocation ble-beacon 1
 hyperlocation ble-beacon 2
 hyperlocation ble-beacon 3
 hyperlocation ble-beacon 4
ap a49b.cd2a.47e4
 policy-tag lewis-home-policy-tag
 rf-tag lewis-home-rf-tag
ap a49b.cd2a.59fc
end
Wed Dec 06 2023 20:03:59 GMT-0600 (Central Standard Time)
#sh ap tag summ
Number of APs: 2
AP Name                 AP Mac           Site Tag Name                     Policy Tag Name                   RF Tag Name                       Misconfigured    Tag Source
Laundry_Room            a49b.cd2a.47e4   default-site-tag                  lewis-home-policy-tag             lewis-home-rf-tag                 No               Static
Hallway                 a49b.cd2a.59fc   default-site-tag                  lewis-home-policy-tag             lewis-home-rf-tag                 No               Static
Wed Dec 06 2023 20:13:24 GMT-0600 (Central Standard Time)
#show wireless client mac-address 88E9.FE56.2CFC detail
Client MAC Address : 88e9.fe56.2cfc
Client IPv4 Address : 192.168.41.29
Client IPv6 Addresses : fe80::102a:3381:c8ef:3a94
Client Username: N/A
AP MAC Address : e44e.2d44.3f20
AP Name: Laundry_Room
AP slot : 1
Client State : Associated
Policy Profile : user-policy-profile
Flex Profile : lewis-home-flex-profile
Wireless LAN Id: 1
WLAN Profile Name: Lewis Home Wireless
Wireless LAN Network Name (SSID): Lewis Home Wireless Test
BSSID : e44e.2d44.3f2f
Connected For : 1054 seconds
Protocol : 802.11ac
Channel : 100
Client IIF-ID : 0x90000009
Association Id : 1
Authentication Algorithm : Open System
Session Timeout : 1800 sec (Remaining time: 746 sec)
Session Warning Time : Timer not running
Input Policy Name  : platinum
Input Policy State : Installed
Input Policy Source : QOS Internal Policy
Output Policy Name  : voice-client-avc
Output Policy State : Installed
Output Policy Source : QOS Internal Policy
WMM Support : Enabled
U-APSD Support : Enabled
  U-APSD value : 0
  APSD ACs    : BK, BE, VI, VO
Fastlane Support : Enabled
Client Active State : Active
Power Save : OFF
Current Rate : m7 ss3
Supported Rates : 9.0,18.0,36.0,48.0,54.0
Mobility:
  Move Count                  : 0
  Mobility Role               : Local
  Mobility Roam Type          : None
  Mobility Complete Timestamp : 12/07/2023 01:55:39 UTC
Client Join Time:
  Join Time Of Client : 12/07/2023 01:55:39 UTC
Policy Manager State: Run
Last Policy Manager State : IP Learn Complete
Client Entry Create Time : 1054 seconds
Policy Type : WPA2
Encryption Cipher : CCMP (AES)
Authentication Key Management : PSK
AAA override passphrase : No
Encrypted Traffic Analytics : No
Protected Management Frame - 802.11w : No
EAP Type : Not Applicable
VLAN : 40
Multicast VLAN : 0
WFD capable : No
Managed WFD capable : No
Cross Connection capable : No
Support Concurrent Operation : No
Session Manager:
  Point of Attachment : capwap_90000006
  IIF ID             : 0x90000006
  Authorized         : TRUE
  Session timeout    : 1800
  Common Session ID: 000000000000004DFCFC842F
  Acct Session ID  : 0x00000000
  Last Tried Aaa Server Details:
  Server IP :
  Auth Method Status List
  Method : None
  Local Policies:
  Service Template : wlan_svc_user-policy-profile (priority 254)
  VLAN             : 40
  Absolute-Timer   : 1800
  Server Policies:
  Resultant Policies:
  VLAN Name         :
  VLAN             : 40
DNS Snooped IPv4 Addresses : None
DNS Snooped IPv6 Addresses : None
Client Capabilities
  CF Pollable : Not implemented
  CF Poll Request : Not implemented
  Short Preamble : Not implemented
  PBCC : Not implemented
  Channel Agility : Not implemented
  Listen Interval : 0
Fast BSS Transition Details :
  Reassociation Timeout : 0
11v BSS Transition : Not implemented
11v DMS Capable : No
QoS Map Capable : No
FlexConnect Data Switching : Local
FlexConnect Dhcp Status : Local
FlexConnect Authentication : Central
FlexConnect Central Association : No
Client Statistics:
  Number of Bytes Received : 11606853
  Number of Bytes Sent : 3220538
  Number of Packets Received : 7352
  Number of Packets Sent : 19559
  Number of Policy Errors : 0
  Radio Signal Strength Indicator : -63 dBm
  Signal to Noise Ratio : 31 dB
Fabric status : Disabled
Client Scan Reports
Assisted Roaming Neighbor List
Nearby AP Statistics:
EoGRE : No/Simple client
Device Type      : Apple-Device
Device Name      : APPLE, INC.
Protocol Map     : 0x000009  (OUI, DHCP)
Protocol         : DHCP
Type             : 12   15
Data             : 0f
00000000  00 0c 00 0b 4a 65 72 65  6d 79 73 2d 4d 42 50      |....Jeremys-MBP |
Type             : 55   16
Data             : 10
00000000  00 37 00 0c 01 79 03 06  0f 6c 72 77 fc 5f 2c 2e  |.7...y...lrw._,.|
Max Client Protocol Capability: 802.11ac Wave 2
NETWORK SWITCH
Wed Dec 06 2023 20:14:50 GMT-0600 (Central Standard Time)
#show run
Current configuration : 35211 bytes
! Last configuration change at 19:58:31 CST Wed Dec 6 2023 by admin
! NVRAM config last updated at 20:54:49 CST Tue Dec 5 2023 by admin
version 17.6
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service call-home
hostname Network_Switch
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 9
no aaa new-model
clock timezone CST -6 0
switch 1 provision c9200l-48p-4g
vtp mode transparent
ip routing
ip name-server 8.8.8.8 1.1.1.1
no ip domain lookup
ip dhcp excluded-address 192.168.10.0 192.168.10.30
ip dhcp excluded-address 192.168.10.50 192.168.10.255
ip dhcp excluded-address 192.168.40.0 192.168.41.0
ip dhcp excluded-address 192.168.41.251 192.168.41.255
ip dhcp excluded-address 192.168.50.0 192.168.50.99
ip dhcp excluded-address 192.168.50.200 192.168.50.255
ip dhcp pool Users
 network 192.168.40.0 255.255.254.0
 default-router 192.168.40.1
 dns-server 8.8.8.8 1.1.1.1
 lease 7
ip dhcp pool WirelessAPS
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.20
 lease infinite
ip dhcp pool Guests
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
 lease infinite
ip arp inspection validate src-mac dst-mac ip
no ip igmp snooping vlan 40
ipv6 nd raguard policy HOST_POLICY
udld enable
 enrollment pkcs12
crypto pki trustpoint TP-self-signed-3080461521
 subject-name cn=IOS-Self-Signed-Certificate-3080461521
 rsakeypair TP-self-signed-3080461521
 certificate ca 01
  D697DF7F 28
  quit
crypto pki certificate chain TP-self-signed-3080461521
  69666963 6174652D 33303830 34363135 3231301E 170D3233 31303133 31373138
  31385A17 0D333331 30313231 37313831 385A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30383034
  36313532 31308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100B797 1D073FC4 4E4C5CDC 8EE01600 27B83FE1 73AE4208 BC54F04A
  59837E1F 99EA26F2 3BC684BA 672EC35D 4BFBE972 ACCC405B 35C1A358 4C2C592B
  0B6B87B5 F184B209 B87E0B06 603E5567 F7395F1B 819ABA5D 0E66D6E9 8B6C5B51
  2DD25FAE 793BEF9C FB991525 B52AC67A 4C7C8CAE 0AF942DB FF68BED7 F6068520
  3283B23E 23D034A5 A8044E03 DB92044A 98BD38FC 3A5BDF91 5F6197F0 EDCBAAA8
  DE6FE12A 34E9DB06 24C7BCBA 1A21C1BC D713AACE 78325ED0 2EB44CA9 5533A5A9
  C659FB56 3A8E53F9 91743AED 84C64CAD 70FB4C2A 2D12D921 F5E4F49C 9667C3BB
  272E3289 64709272 EC4BFCAA 13C1FB9B F0D33490 FE548B29 0DCD68E2 C967411C
  2057CB32 BC110203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 14ADECF5 AD057734 6DF16F3F 453CAB16 196ADAE2
  62301D06 03551D0E 04160414 ADECF5AD 0577346D F16F3F45 3CAB1619 6ADAE262
  300D0609 2A864886 F70D0101 05050003 82010100 300171BA 24314A30 1028420D
  441CDA1B 03A67233 F945784B 5C11E6CF 153CE808 CC0FDF73 4D6971E1 2B256099
  EC7D833C 91E58898 FCA08678 17EAF0DF B366DDA7 7C34ED2B 5095B7ED E9230FF8
  55D0B1CF C2664814 5AC73853 0BF3B1C4 27D99A0F 7930060E 5D9CBD69 F1FDBBCD
  5F0AC646 A1B53915 CFE060B0 ED48E411 99C3AD9D A60FB342 F3B28AA0 B41B7ACE
  B2C953B2 FD06E6A3 5F2B70B1 D5B36C52 53F81373 22D84EEF F21A6F08 4D0D76DD
  9FCAF102 7D4CA143 ACB2D039 FF9ECD9D C2631359 9FD55E40 FEC7B423 9BEEAD8C
  D1EEF19A 8AD2FE2E 13C11750 8590F65F F67D257E 08CDD2DC FC48F80A 3B107FEA
  652D0582 F6B3FEC1 F045FF7D B5360E73 C9CA4932
  quit
port-channel load-balance src-dst-ip
license boot level network-advantage addon dna-advantage
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
spanning-tree vlan 40,50,60 priority 4096
spanning-tree vlan 250 priority 20480
memory free low-watermark processor 10633
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause psp
errdisable recovery cause mrp-miscabling
errdisable recovery cause loopdetect
redundancy
 mode sso
transceiver type all
 monitoring
vlan 8
 name Native
vlan 9
 name Blackhole
vlan 10
 name Managment
vlan 40
 name Users
vlan 50
 name Guests
vlan 60
 name Voice
vlan 70
 name Security
vlan 80
 name Video
vlan 100
 name Audio
vlan 250
 name WAN
class-map match-any system-cpp-police-ewlc-control
  description EWLC Control
class-map match-any MULTIMEDIA-STREAMING-QUEUE
 match dscp af31
 match dscp af32
 match dscp af33
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any CONTROL-MGMT-QUEUE
 match dscp cs7
 match dscp cs6
 match dscp cs3
 match dscp cs2
class-map match-any TRANSACTIONAL-DATA-QUEUE
 match dscp af21
 match dscp af22
 match dscp af23
class-map match-any system-cpp-default
  description EWLC data, Inter FED Traffic
class-map match-any VIDEO-PRIORITY-QUEUE
 match dscp cs5
 match dscp cs4
class-map match-any system-cpp-police-sys-data
  description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any BULK-SCAVENGER-DATA-QUEUE
 match dscp af11
 match dscp af12
 match dscp af13
 match dscp cs1
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
  description High Rate Applications
  description MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any MULTIMEDIA-CONFERENCING-QUEUE
 match dscp af41
 match dscp af42
 match dscp af43
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any PRIORITY-QUEUE
 match dscp ef
class-map match-any system-cpp-police-ios-routing
  description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
  description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map 2P6Q3T
 class PRIORITY-QUEUE
  priority level 1
  police rate percent 10
 class VIDEO-PRIORITY-QUEUE
  priority level 2
  police rate percent 20
 class CONTROL-MGMT-QUEUE
  bandwidth remaining percent 10
  queue-buffers ratio 10
 class MULTIMEDIA-CONFERENCING-QUEUE
  queue-limit dscp af43 percent 80
  queue-limit dscp af42 percent 90
  queue-limit dscp af41 percent 100
 class MULTIMEDIA-STREAMING-QUEUE
  queue-limit dscp af33 percent 80
  queue-limit dscp af32 percent 90
  queue-limit dscp af31 percent 100
 class TRANSACTIONAL-DATA-QUEUE
  queue-limit dscp af23 percent 80
  queue-limit dscp af22 percent 90
  queue-limit dscp af21 percent 100
 class BULK-SCAVENGER-DATA-QUEUE
  bandwidth remaining percent 5
  queue-limit dscp values  cs1 af13 percent 80
  queue-limit dscp values  af12 percent 90
  queue-limit dscp values  af11 percent 100
 class class-default
  bandwidth remaining percent 25
  queue-buffers ratio 25
policy-map system-cpp-policy
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 192.168.10.20 255.255.255.0
interface GigabitEthernet1/0/1
 switchport access vlan 40
 switchport mode access
 switchport port-security maximum 11
 switchport port-security violation restrict
 switchport port-security aging time 2
 switchport port-security aging type inactivity
 ip arp inspection limit rate 100
 ipv6 nd raguard attach-policy HOST_POLICY
 spanning-tree portfast
 ip verify source
 ip dhcp snooping limit rate 100
interface GigabitEthernet1/0/2
 ip verify source
interface GigabitEthernet1/0/3
 ip verify source
interface GigabitEthernet1/0/4
 ip verify source
interface GigabitEthernet1/0/5
 ip verify source
interface GigabitEthernet1/0/6
 ip verify source
interface GigabitEthernet1/0/7
 ip verify source
interface GigabitEthernet1/0/8
 ip verify source
interface GigabitEthernet1/0/9
 ip verify source
interface GigabitEthernet1/0/10
 ip verify source
interface GigabitEthernet1/0/11
 ip verify source
interface GigabitEthernet1/0/12
 ip verify source
interface GigabitEthernet1/0/13
 ip verify source
interface GigabitEthernet1/0/14
 ip verify source
interface GigabitEthernet1/0/15
 ip verify source
interface GigabitEthernet1/0/16
 ip verify source
interface GigabitEthernet1/0/17
 ip verify source
interface GigabitEthernet1/0/18
 ip verify source
interface GigabitEthernet1/0/19
 ip verify source
interface GigabitEthernet1/0/20
 ip verify source
interface GigabitEthernet1/0/21
 ip verify source
interface GigabitEthernet1/0/22
 ip verify source
interface GigabitEthernet1/0/23
 ip verify source
interface GigabitEthernet1/0/24
 ip verify source
interface GigabitEthernet1/0/25
 ip verify source
interface GigabitEthernet1/0/26
 ip verify source
interface GigabitEthernet1/0/27
 ip verify source
interface GigabitEthernet1/0/28
 ip verify source
interface GigabitEthernet1/0/29
 ip verify source
interface GigabitEthernet1/0/30
 ip verify source
interface GigabitEthernet1/0/31
 ip verify source
interface GigabitEthernet1/0/32
 ip verify source
interface GigabitEthernet1/0/33
 ip verify source
interface GigabitEthernet1/0/34
 ip verify source
interface GigabitEthernet1/0/35
 ip verify source
interface GigabitEthernet1/0/36
 ip verify source
interface GigabitEthernet1/0/37
 ip verify source
interface GigabitEthernet1/0/38
 ip verify source
interface GigabitEthernet1/0/39
 ip verify source
interface GigabitEthernet1/0/40
 ip verify source
interface GigabitEthernet1/0/41
 ip verify source
interface GigabitEthernet1/0/42
 ip verify source
interface GigabitEthernet1/0/43
 description Laundry Room Wireless Access Point
 switchport trunk native vlan 10
 switchport trunk allowed vlan 10,40,50,60,70,80,100
 switchport mode trunk
 spanning-tree portfast disable
 ip verify source
interface GigabitEthernet1/0/44
 ip verify source
interface GigabitEthernet1/0/45
 description Hallway Wireless Access Point
 ip verify source
interface GigabitEthernet1/0/46
 ip verify source
interface GigabitEthernet1/0/47
 switchport access vlan 10
 ip verify source
interface GigabitEthernet1/0/48
 ip verify source
interface GigabitEthernet1/1/1
 description Link to Edge Router
 switchport access vlan 250
 switchport trunk native vlan 8
 ip arp inspection trust
 logging event trunk-status
 load-interval 30
 ip dhcp snooping trust
interface GigabitEthernet1/1/2
 switchport trunk allowed vlan 40,60
 load-interval 30
interface GigabitEthernet1/1/3
 load-interval 30
interface GigabitEthernet1/1/4
 load-interval 30
interface Vlan1
 no ip address
 shutdown
interface Vlan8
 description Native
 ip address 192.168.8.1 255.255.255.0
interface Vlan9
 description Blackhole
 ip address 192.168.9.1 255.255.255.0
interface Vlan10
interface Vlan40
 description Users
 ip address 192.168.40.1 255.255.254.0
interface Vlan50
 description Guests
 ip address 192.168.50.1 255.255.255.0
interface Vlan60
 description Voice
 ip address 192.168.60.1 255.255.255.0
interface Vlan70
 description Security
 ip address 192.168.70.1 255.255.255.0
interface Vlan80
 description Video
 ip address 192.168.80.1 255.255.255.0
interface Vlan100
 description Audio
 ip address 192.168.100.1 255.255.255.0
interface Vlan250
 description WAN
 ip address 192.168.250.1 255.255.255.0
router ospf 1
ip default-gateway 192.168.250.10
ip http server
ip route 0.0.0.0 0.0.0.0 192.168.250.10
ip ssh time-out 60
ip ssh version 2
ip scp server enable
control-plane
 service-policy input system-cpp-policy
banner login ^CNetwork Switch^C
line con 0
 exec-timeout 0 0
 stopbits 1
line aux 0
line vty 0 4
 login local
 length 0
 transport input telnet
 transport output telnet
line vty 5 15
 login local
 length 0
call-home
  active
end
OK one thing to note after reconfiguration, The primary access point seems to work just fine. I’m able to connect to it every time when I’m right beside it. If I walk over to the other access point, so that I connect to it, it spins and spins and spins, and never gets an IP address. Then I walked back to the primary access point, and I connect right away. Maybe that’s a clue.
Can you do a "show ap name Laundry_Room tag detail" and "show ap name Hallway tag detail" just to see all of the tag config on the APs.
At a glance I don't see any obvious issue.
I'm surprised you've disabled spanning-tree portfast on the AP switch ports - you're sure there's no vlan blocking happening there?  We use:
spanning-tree portfast trunk
spanning-tree portfast edge trunk
spanning-tree bpdufilter enable
spanning-tree bpduguard disable
Let me check those. I just rebooted the switch and the access points powered up differently so that the hallway became the active ewc this time. Now devices will connect it just fine and not the other access point. It seems like even though both access points are broadcasting, only the active one works.
Thu Dec 07 2023 20:51:35 GMT-0600 (Central Standard Time)
#show ap name Laundry_Room tag detail
AP Name            : Laundry_Room
AP Mac             : a49b.cd2a.47e4
Tag Type             Tag Name
Policy Tag           lewis-home-policy-tag
RF Tag               lewis-home-rf-tag
Site Tag             default-site-tag
Policy tag mapping
WLAN Profile Name                Policy Name                      VLAN                             Flex Central Switching           IPv4 ACL                         IPv6 ACL
Lewis Home Guest                 guest-policy-profule             NA                               DISABLED                         Not Configured                   Not Configured
Lewis Home Wireless              user-policy-profile              NA                               DISABLED                         Not Configured                   Not Configured
Site tag mapping
AP Profile           : lewis-home-ap-profile
Local-site           : No
RF tag mapping
5ghz RF Policy       : Global Config
2.4ghz RF Policy     : Global Config
Thu Dec 07 2023 20:52:24 GMT-0600 (Central Standard Time)
#show ap name Hallway tag detail
AP Name            : Hallway
AP Mac             : a49b.cd2a.59fc
Tag Type             Tag Name
Policy tag mapping
Site tag mapping
Local-site           : No
RF tag mapping
  -  Validate the tag configuration using the following command:  # wireless config validate
 M.
       Beauty and terror
      Just keep going
       No feeling is final
