Showing results forĀ
Search instead forĀ
Did you mean:Ā
WCS 7.0 with ACS 5.1
vinodjad1234
Level 2
Level 2
I want to add WCS as a AAA client for authentication with Radius  in my set-up.
how to configure WCS for the same.
where are all those options in WCS.
Please guide me for the same.
Hi Vinod,
See this : http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0admin.html#wp1191980
It's from the Cisco Wireless Control System Configuration Guide, Release 7.0 , Chapter 18 - Administrative Tasks.
You should be able to follow the steps and achieve what you are looking for...
Cheers
Volven
7 Replies 7
Surendra BG
Here is the link..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080851f7c.shtml#topic5
lemme know if this answered your question..
Surendra
Surendra BG
The link which you have shared knowledge is related to ACS 4.0 and WCS with tacacs , I need details about WCS with Radius and ACS 5.1.
Please share knowledge for the same.
thanks for your time.
Hi Vinod,
Cheers
Volven
Thanks for sharing the link,
Have you worked on WCS 7.0 ?
Have worked on it in the LAB, will be doing a deployment in Jan.
Cheers
Volven
Has anybody got any experience with trying the config as depicted in the WCS 7 config guide?
I have tried today to integrate WCS 7 with ACS 5.1 and got a partial success.  I have created a unique Shell Profile that invokes for the WCS only which contains 1 role (role0=Root) and 73 task entries (as copied from the WCS group pages) and I can log in to WCS with the new account, but some things I dont appear to have priviledges for, such as Reports.  Is there any way to debug which task WCS thinks I dont have to do this?  Any other ideas?
I did this recently and it worke ok.
Check all of the tasks are included correctly
