WCS and WLC WLAN Config not fully in sync
chanseeyee
We're facing the issue WCS and WLC WLAN Config is not fully in sync. WLC  showing server 1 is IP:10.160.22.151, Port:1812 but WCS server showing none even  after click on “Audit” button. Any idea how to resolve this issue? Is this causing any wireless problem? Attached is screen captured. Thanks for your help.
8 Replies 8
art-barrera
Have you first created the security server on WCS and then apply to controller.
Then apply your WCS WLAN template.
When you apply the WLAN template its going to check that what your asking for is available on the controller or fail. You should have been given a detailed error when applying the WLAN template.
//art
You mentioned "audit". Have you done a WCS audit so the WLC and WCS are in SYNC?
If you make a change on the WLC you will not see it in WCS UNLESS they are SYNC. You will see the term "mismatch".
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Yupp.. we already done the "audit" on WCS and found that WLC and WCS are not in SYNC..which is as attached in my previous screen captured.
WCS shows instead of "mismatch" it shows "identical" ?
Its should show "mismatch"... Let me schedule with our client and check on it first..
art-barrera
Also make sure you are doing a template based audit and not just a basic.
//art
Scott Fella
Just click the box in the controller that is mismatched and from the drop down menu choose refresh config from controller. Then when the window changes choose either retain or replace. I usually replace since I know my WLC has the correct info. Then hit apply and that should do it. I try not to use the audits that much anymore due to having to make sure the clients keeps up with the templates and all the changes.
-Scott
Also what version is your WCS and the WLCs on. Best pratice and rule of thumb is to have WCS on the same rev or HIGHER than the WLC.
