12-05-2012 08:24 AM - edited 07-03-2021 11:10 PM
Hello
We are having an ongoing issue with WLC 7.2.111.3 running on an SRE module inside a 2911. The WLC is rebooting a couple times a day, we have RMA'd the 2911 and the SRE module and the problem still remains. We have two SSIDs, one for employees doing radius auth and a guest network doing web-auth. We are using a single LLWAP and nothing out of the ordinary.
Cisco TAC has been helpful but even they can't seem to figure out what the problem is. The logs give little information as they are cleared when the WLC reboots and if I am not consoled into it logging the session I don't see any message of it going down.
This what I see on the console when it reboots, has anyone had problems or see this before?
(Cisco Controller) >
(Cisco Controller) >Oops: 0000 [#1]
PREEMPT
Modules linked in: sshquicksec(P) wlc_dtl(F) wlc_fp(P) wlc_af(P) cisco_quack(P)
CPU: 0
EIP: 0060:[<c0104c9d>] Tainted: PF VLI
EFLAGS: 00010087 (2.6.21_mvlcge500-octeon-mips64_octeon_v2_be #1)
EIP is at dump_trace+0x5a/0x93
eax: 00000000 ebx: 6e692f6e ecx: 6e692f6e edx: c034ef56
esi: 3a786165 edi: 6e692000 ebp: 6e692ffd esp: dfdb1058
ds: 007b es: 007b fs: 00d8 gs: 0000 ss: 0068 preempt:00000003
Process softirq-net-rx/ (pid: 6, ti=dfdb0000 task=dfec3830 task.ti=dfdb1000)
Stack: 0000007a c034ea4d dfec3830 dfdb1000 dfdb1ffd c0104cf1 c03a6910 c034ea4d
00000001 c0119a0c c0105371 c034ea4d c01053f3 dfdb1098 c0136670 c034e1ca
c035664c 00000053 c030b89c 00000001 c0119a0c c0119a0c 00000000 00000000
Call Trace:
[<c0104cf1>] show_trace_log_lvl+0x1b/0x36
[<c0119a0c>] vprintk+0x11/0x2a1
[<c0105371>] show_trace+0xf/0x11
[<c01053f3>] dump_stack+0x12/0x14
[<c0136670>] add_preempt_count+0x41/0xbe
[<c01bff1f>] vsnprintf+0x43a/0x476
[<c010655b>] do_IRQ+0x7a/0xe7
[<c0119cb7>] printk+0x1b/0x1f
[<c013666b>] add_preempt_count+0x3c/0xbe
[<c0104847>] common_interrupt+0x23/0x28
BUG: unable to handle kernel paging request at virtual address 6e692034
printing eip:
c0104cac
*pde = 00000000
Oops: 0000 [#2]
PREEMPT
CPU: 0
EIP: 0060:[<c0104cac>] Tainted: PF VLI
EFLAGS: 00010046 (2.6.21_mvlcge500-octeon-mips64_octeon_v2_be #1)
EIP is at dump_trace+0x69/0x93
eax: 00000000 ebx: 6e692ffd ecx: c03a6910 edx: c034ef56
esi: 50f8458d edi: 6e692000 ebp: 6e692ffd esp: dfdb0ef0
Stack: c01c002d c034f0ea 00000000 00000000 c034f0ea c0104cf1 c03a6910 c034f0ea
dfdb10bb 00000018 c0104dac c034f0ea c034f0ea dfdb1020 dfdb1058 00000002
c04298c8 c0104c9d dfdb1020 c0104f9d c034f0ea 00000010 dfec39d8 00000006
Call Trace:
[<c01c002d>] snprintf+0x1f/0x22
[<c0104dac>] show_stack_log_lvl+0xa0/0xad
[<c0104c9d>] dump_trace+0x5a/0x93
[<c0104f9d>] show_registers+0x1e4/0x2e0
[<c01049b7>] kernel_thread_helper+0x7/0x10
[<c01051af>] die+0x116/0x1ed
[<c0113c7b>] do_page_fault+0x4a7/0x578
| preempt count: c01137d4 ]
| 24-level deep critical section nesting:
.. [<c0115d25>] .... task_rq_lock+0x12/0x19
.....[<00000000>] .. ( <= _stext+0x3feff000/0x14)
.. [<c021c365>] .... iegbe_xmit_frame+0x298/0x948
.. [<c01050db>] .... die+0x42/0x1ed
.. [<c01196cf>] .... release_console_sem+0x51/0x1cf
.. [<c0119a7b>] .... vprintk+0x80/0x2a1
.. [<00000000>] .... _stext+0x3feff000/0x14
Code: 00 00 eb 10 8b 4c 24 18 89 f2 8b 44 24 1c ff 51 08 83 c3 04 39 fb 76 23 39 eb 73 1f 8b 33 89 f0 e8 96 33 02 00 85 c0 74 e8 eb d9 <8b> 4f 34 85 c9 74 1d 89 cb e8 18 ad 00 00 eb b9 8b 4c 24 18 ba
EIP: [<c0104cac>] dump_trace+0x69/0x93 SS:ESP 0068:dfdb0ef0
note: softirq-net-rx/[6] exited with preempt_count 2
Clocksource tsc unstable (delta = 28120727222 ns)
Time: acpi_pm clocksource has been installed.
At this point looking to see if anyone has insight or thoughts on what could be causing this.
TIA
12-05-2012 08:29 AM
There actually is a known issue with the SRE and 7.2 code. one of my customers was having the same issue.
CSCua08891, the fix is in 7.3
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
