WGB cannot authenticate to network after WLC firmware upgrade
l.buschi
Level 2
Level 2
I have a mesh network working with 3504 WLC and Firmware 8.5.X.
On this network I have associated some WGB made with standalone APs (1262 and 1242) authenticated with WPA2 - PSK.
This is my standalone ap configuration:
dot11 ssid xxx
authentication open
authentication key-management wpa version 2
wpa-psk ascii 7 xxx
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid xxx
antenna transmit right-a
antenna receive right-a
station-role workgroup-bridge
mobile station scan 2412 2437 2462
mobile station minimum-rate 11.0
mobile station period 10 threshold 80
bridge-group 1
bridge-group 1 spanning-disabled
this APs perfectly work with 8.5 release and don't work with 8.10.X
My rap and map APs are AIR-AP1562E-E-K9
balaji.bandi
i would first check the compatable matrix ? is this supported ?
BB
l.buschi
Level 2
Level 2
Air-ap1242 are use as standalone access-point with wgb role.
No particular restrictions can be found
