What is Aironet IE? I have my clients disconnected from when uncheck the Aironet IE in WLC 5520
KAN41R
Sandeep Choudhary
Aironet IE contains information, such as the access point name, load, number of associated clients, and so on sent out by the access point in the beacon and probe responses of the WLAN. CCX clients use this information to choose the best access point with which to associate.
My recommandation is to disable it.
Dont forget to rate helpful posts
10 Replies 10
Sandeep Choudhary
Hi Snadeep,
Thank you very much!!! so we have Cisco Jabber client for instant chat and Cisco VIOP phone users at our site, so if we disble it does it affect the performance on existing ???
HI Ramesh,
Yes, Changing WLAN parameters while it is enabled then it will cause the WLAN to be disabled for a moment and thus may result in loss of connectivity for some clients.
Hi ,
So if Aironet IE is enabled will it cause disconnection issue for clients ?
Can it possible cause issue with some devices.  Sure it can.  Something that you would need to test yourself in your environment.  I typically leave it disabled especially on a guest network.
-Scott
Thank you Scott, I waned to say it cause issues for client to  connect to the network ? or it cause issues by having the clients disconnecting randmoly after they are already connected ?
because I have tickets that users connects fine but then they get disconnecting many times randomly during the day , so was wondering if disabling Aironet IE mihgt help here
It’s worth a try. It will not make things worse. This way you can follow up with a user and actually understand if that changes helped or not.
You should gather more information as it can be other things. See if it’s isolated to an SSID, a certain device or NIC, NIC driver, area, etc.
-Scott
Hi Scott,
got approval to disable Aironet IE , will this is  affect the running mesh network ?
Cheers,
Could we know why your recommendation is to disable it? It seems like the Aironet IE information helps to have better connections to the APs, doesn't it?
Kind regards.
@Luis Antonio Fernandez refer to
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#AironetIE
Our site installers sometimes ask us to turn it on when doing site surveys because it allows them to see the power level reported by the AP.
