WIFI 6 solution - Controller - licensing and support
Hello Experts  @balaji.bandi   @Marvin Rhoads   @Rob  @Richard  @georg
I am looking to add Cisco Catalyst 9120 APs to 3 different sites and got few questions?
Does Cisco Provide any cloud management for Wireless APs which eliminate the need of physical controller?
In case Physical Controller is only choice, Do i need one for each site ?  or it will be one fine for all sites (Considering all sites are connected by IPSec)?
How does licensing work with it ?  Is it just one time buy and then annual support ?
Lovejit Singh
balaji.bandi
You can use virtual controller in terms of Cisco AP concern :
https://www.cisco.com/c/en/us/products/wireless/virtual-wireless-controller/index.html
If you looking managed device using cloud then look at Meraki.
BB
I'd suggest new 9800 series not AireOS virtual WLC!
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Leo Laohoo
Cisco Mobility Express
ME - not for 9120!
For 9120 you want Embedded Wireless Controller with Catalyst Access Points https://www.cisco.com/c/en/us/products/wireless/embedded-wireless-controller-on-catalyst-access-points/index.html but that is *not* a cloud management option.
