Wildcard Certificate accepted by Wireless Lan Controller?
holgerseiler
Hi all,
I have a hopefully short question. I have 3 WLC 5508 and a NAC guest server. We want to download a wildcard certificate after a few seconds at the download of this certificate I got the failure message download failed.
Accept the WLC wildcard certificates or must I generate a SAN (Subject Alternative Name) Certificate.
Every help is welcome.
Thanks and kind regards
Holger
It's actually not in any document. But you're right and it should be.
I just filed a documentation bug to have the type of certificates supported clearly documented on cisco.com
Nicolas
5 Replies 5
Nicolas Darchis
Yes, Wildcard certificates are supported.
However, it seems there is still a problem with wildcards certificates if they are chained :
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsy88149
But I never tested that situation myself.
Nicolas
Hi Nicolas,
thanks for the support. Could you give me a note in which document I will find which certificates are supported at WLC.
Thanks for the Bug-ID,too. I think we have another issue, because I got a failure from the WLC at the download. I think it is possible that the certificate is damaged.
Holger
Nicolas
Thank you very much
Holger
Hi guys,
I'm also looking to use a wildcard cert for this purpose.  I just checked your bug-id and its seems it's been closed with a workaround of not using wildcard certs.  I'm not sure if this is specific to that version, so I was wondering if you guys know if wildcards are supported in v7.0?
Rob
