wireless-5ghz
Anjana A
Level 4
Level 4
Hello Team,
Whether more noise level will cause teams call disconnection.
Todays users reported teams call disconnection and during that time got the report from dnac for high noise level
what all the parameters will cause more noise issue in 5ghz.
Ap model:3700
WLC:5520
ios:8.10.151.0
SSID:801.x
Anjana
AdamF1
Level 5
Level 5
It's interference, you would need to scan the air to see what is causing the issue. DNAC can give you some information from a 3700 as long as clean air is turned on.
Scott Fella
Some things to also gather while you troubleshoot is, make sure you don't see any radar traps during that time.  Also look at the client count on that given ap.  When users have issues, are they all close by each other or on different locations?  If other users in other locations don't have issue, then you can focus more on the area where users are complaining.  It can be more that just wireless or interference contributing to that.  I would also look at what devices, drivers, Teams version users have and try to isolate if there is a combination that works well and if there is a combination in which users just complain.
-Scott
Leo Laohoo
Just looking at the surface, there are many vital information that have been left out or not included:
  • Is this only affecting MS Teams?
  • Is this "across the board" or just affecting MS Teams user(s) in a particular part of the building?
  • What channel width is enabled on the WLC?
  • What channel are the affected APs on?
  • Has anyone verified this issue is happening or is this just "hear-say" from someone?
  • What kind of platform is used, laptop, smartphone, tablet, etc?
  • What OS is the issue predominantly present, Android, MAC OS, Apple iOS, Windows, Linux?
Rich R
And consider updating to latest TAC recommended version of code to get latest bug fixes but take note of the various field notices below.
Also consider whether there could be congestion on your backhaul or Teams itself.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
