Wireless clients cannot access WLC Management interface..
Anvar Mohammed
Level 3
Level 3
wireless clients can ping wlc management ip but can not access controller web interface,
management via wireless clients are allowed at wlc confgiuration,
i can access it through dynamic interface,, but not through management ip
attached sh-run config
thanks,
anvar
6 Replies 6
Stephen Rodriguez
This is a bad thing?
What is the issue, do you want your clients to be able to manage the WLC?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
i had implemented more than 20 controllers, were i didn't find this case before, so i just need to know why it should not work.
basically i don't need wireless clients to access WLC management interface,, but why it is not working ??? while i can ping it,, but no SSH or GUI
thanks,
anvar
Just came across same scenario!
Access to WLC management interface from its own wireless clients is blocked by default. But it can be enabled manually,
Management-->Mgmt via Wireless (on left side)---> click the check box on page to enable (self explanatory)
Hi there.
I can't see you file, one question your WLC is in HA SSO mode?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
As per config attached Mgmt via wireless is enabled , secure webmode is also enabled. Please try accessing WLC via https:// , http would not work.
By the way Cisco would not recommend enabling Mgmt via wireless access unless there is a requirement from the Customer.
Thanks and regards,
Manas Pratap Singh
Vengatesa Prasath
Have you tested with client on same subnet of wireless management interface? if so what is the status.
Is it possible to collect uplink capture from WLC? Working and non working scenario (working: When tried with dynamic inerface && Non working: When tried with management interface)
