wireless clients loosing connection to sql server
dafydd.baldwin
Community Member
We have a client that are using AP1200 with cisco PI21AG pci desktop cards. They are connecting to an sql server but intermitantly throughout the day they seem to get disconnected from the sql session. This only started happening since they went wireless. Anyone have any ideas.
thanks
will.shaw
Level 4
Level 4
Are they set to reauthenticate after a certain interval?
right now they are trying out wireless. They are set to basic WEP encrytion and no kind of authentication.
thanks
What is the ADU version? Please check CSCef00136 and find out if you got disconnect/disassociate when you roam from one AP to another AP.
