wireless control system
dkblee
Level 7
Level 7
hi! If i did not select the "Apply to AccessPoint" during the creation of new controller template process wizard thru the Controller Template Launch Pad (assuming that i;ve successfully applied the template to wlc), will i be able to apply/see the AP in the Lightweight AP template creation (select APs tab)? What's the different between adding the AP in the controller template launch pad and Lightweight AP template creation page? Must i include the AP into the controller template launch pad before i can see it in the Lightweight AP template creation page?
Thx
Nicolas Darchis
if I understood correctly what you were talking about, applying a template on APs through the controller launch pad applies it to all APs currently associated to a controller while selecting APs manually in the AP template launch pad applies it to selected APs regardless of the WLC they are on.\\
How do APs appear in the select list of the templates ? Simply by WCS knowing them, so usually by being associated to an WLC that WCS knows.
Nicolas
