Wireless Controller 9800
wonderk
Frequent Visitor
Frequent Visitor
Hi Family, I need your help. I'M unable to access Cisco catalyst 9800 series wireless control through GUI (two of my colleagues can) however I can ping and access it via putty.
7 Replies 7
JPavonM
Check you have HTTP server enabled on the WLC and, if using HTTPS check you are using a trustpoint you've previously generated (https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_web_admin_settings.html)
Mark Elsen
        - What happens then, when you try ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Ruben Cocheno
@wonderk
Try a traceroute back to the WLC IP, and compare with one of your colleagues, also check Firewall rules and/or routing allong the way including on the WLC itself just in case
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Change the browser you use
MHM
balaji.bandi
You need to compare working IP address and your IP address - as other suggested check the browsers. ( TLS settings if any)
BB
Haydn Andrews
Can you access the login page or you cant even reach that?
*****Help out other by using the rating system and marking answered questions as "Answered"*****
nachoGrande
Frequent Visitor
Frequent Visitor
open a command line and (make sure telnet is enabled) and type:
telnet 182.adress.x.x 443 and does it open or say it cant connect
