WLC9800 flexconnect can't access management web
Wei Ting Lin
I am under flexcennect and cannot log in to the management page when using wifi.
I confirm that Management Via Wireless is checked.
5 Replies 5
pieterh
AFAIK The "Management Via Wireless" setting concerns the traffic that is forwarded from the Access point over a CAPWAP tunnel to the controller
when using Flexconnect, the Access-point drops the packets onto the configured (V)LAN on the switchport
from there the controller sees no difference ?
=> as long vlan and routing configuration is ok and no ACL's block the traffic you should be able to access the management page.
 same as a wired connection from the same vlan
Haydn Andrews
From a wired connection in the same VLAN that the flexconnect user is in can you access the WLC?
*****Help out other by using the rating system and marking answered questions as "Answered"*****
I can not ping WLC9800 IP and access web management, But I can ping the AP IP in the same network segment.
I have done tests on almost the same network segment, using different settings of local and flexconnect. In local mode, I can access the management page.
This is what makes me feel weird......
this matches my statement that over a capwap tunnel (local mode) the setting "management over wireless" is used
=> connect a PC wired on the same vlan, and test connectivity to the WLC, I expect this to fail too
if it does fail, than you need to troubleshoot from there
