Wireless Help Needed
ross_rulz
Level 5
Level 5
Hi at the moment at my work we have 4 Cisco 1240 wireless access points. One of which is the root and is connected to a radius server. The other 3 are just configured as normal access points. The problem I have is that some people can connect to some access points and some cannot. The thing I have noticed is that the 3 access points dont have the radius server settings on them. Dont know why this is like this but I want to know should all access points be setup for the radius server or is it only the root access point? I look forward to your replies.
Ross.
srosenthal
Level 8
Level 8
If you are using the radius server for client authentication you will need to have the same config on all of the access points.
Seth Rosenthal CWNE#55
