wireless QoS
Tazio4436
Level 5
Level 5
I have 2 SSIDs and have been asked to limit the bandwidth of Guest ssid.
I check both SSIDs and both have QoS as shown below. Please see File 1.
MY first question is which one of the QoS is it using right now as I think that is is not using any specific. (Platinium,Gold , Silver or Bronze)
I have been asked to limit the bandwith for Guest to 100M and give the other SSID the maximum bandwidth.
Can anyone help me to implement this please.
Tazio
7 Replies 7
Scott Fella
I would suggest you take a look at a few guides on WLC bandwidth limits.  Here is one that shows you have to implement bandwidth, but there are a lot more out there for reference.
Wireless Bi-Directional Rate Limiting Deployment Guide - Cisco
-Scott
Thanks a lot , i am going through the document.
Tazio
jagan.chowdam
Here is an other good blog post about rate limit
https://mrncciew.com/2013/05/01/per-user-rate-limit-in-wlan/
CJ
Leo Laohoo
Is this a 2504?
QoS Bandwidth Contracts are only supported on 5508/WiSM2, 5520/8540/3504.  2504 does not support this feature.
Yes it is a 2504.
Does this means i cannot control bandwidth on 2504 or there are other ways?
Tazio
What about enforcing the limits on the upstream device/firewall?
And it is too long ago to really remember, but I think I had it running on the 2504 that I used one Interface for guest with 100 MBit Port-speed and the other interface with Gigabit because in that network there was no device that could do bandwidth-limits.
Won't win any design awards, but if I remember right, it worked as expected.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Enable traffic-shaping policy in the core.
