Wireless system simulation
Torsten Austerlitz
Community Member
Good day
I need to find a system that can simulate wireless network.
I use packet tracer it does not meet my needs, the device is very small and does not have enough features
6 Replies 6
Mark Elsen
  -  Usually wireless is not deployed-tested in that manner ; and actually in  a physical place or environment
     that is not sufficient; you will always need a wireless Site Survey when it comes down to placing APs
     taking into account building and room layouts, walls ,....
   M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
If this required real deployment then contact local partner help you and show you demo
or if you have budge, buy AP and install virtual WLC and test it.
BB
Rich R
You can run virtual 9800 series WLC - https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-cl-wireless-controller-cloud/nb-06-cat9800-cl-cloud-wirel-data-sheet-ctp-en.html but you'll still need real APs to connect to the WLC.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Haydn Andrews
What exactly are you wanting to simulate?
If its practice with configuration the 9800-CL can be deployed to a number of hypervisers or into Cloud.
You can even run on VM Workstation, or Fusion
If its simulation of what the RF will do than there is Hamina, Ekahau, AirMagnet to do predictive designs.
If its client load then it gets real expensive real fast as specialist tools that have big $$$s for them
If its for lab work, there are things like dCloud, but its best to aquire an AP, Switch and setup 9800-CL on a VM and practice
And if you dont want to go down that path, there are always CCIE rack rentals that will have WLCs, DNACs, Switchs, APs, ISE and Clients that you can pay to book X number of hours to do the simulation using their real gear
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Scott Fella
I'll add to all the great comments and this is my opinion.  You can't simulate a wireless environment unless you have equipment. There is no way I would trust any virtual software to do any of my testing I need to do to test a feature or push to production.
-Scott
srimal99
Level 5
Level 5
If you need a home lab set up you can buy a
  1. Cisco 9105
  2. Cisco 9115
  1. Cisco 9120
    and set up as Work bridge group , you can get used to UI and CLI of 9800. I have similar set up .
    As @Haydn Andrews There are many options depends on your preference.
