wlan 2500 Wireless controller
sramirezg
Community Member
How to config a wlan 2500 / AIR-CT2504-K9 V01 PoE controller with AIR-CAP2602I-N-K9 Access Points?.
millerlw
Level 3
Level 3
Look at this page, there are config guides with examples.
http://www.cisco.com/c/en/us/support/wireless/2504-wireless-controller/model.html
Leonard
Hello Sergio,
Please look into the below link it has configuration guides and tech notes as well.
http://www.cisco.com/c/en/us/support/wireless/2500-series-wireless-controllers/products-configuration-examples-list.html
mohanak
The Power over Ethernet (PoE) ports on the Cisco 2500 Series Wireless Controller will not support directly attached APs although those APs might power up and join, it is not a supported scenario.
http://www.cisco.com/c/en/us/support/docs/wireless/2500-series-wireless-controllers/113034-2500-deploy-guide-00.html#anc5
