WLAN DHCP Addr. Assignment Required via CLI
andrew-hunt
Visitor
Hello all,
Is anyone aware of the CLI command to enable / disable the DHCP Addr. Assignment required WLAN option on a 5508 controller running 7.2.110.0 code? I don't seem to be able to find it documented anywhere, and if it is available via CLI it's not intuitive.
Thanks for any insight anyone can shed,
Andrew.
Scott Fella
That has to be performed from the GUI. I had ran into that a while back and I usually Dona lot of my configuration from the CLI, but couldn't find how to set that and put an address.... Well there wasn't one for the CLI.
-Scott
