Bookmark
Subscribe
2444
WLC 2504, directly connected APs
c.s
I need to configure a 2504 wlc and two 1142 APs that I want to connect directly to the wlc. I've heard I can't use the PoE on port 3 and 4. If so, can I use power injectors instead?
I can't seem to get the APs to speak to the wlc. Using example below, how would I go about configuring this andwhen do i need to enable Dynamic AP Management? Appreciate all suggestions.
Example:
mgmt vlan 10
guest vlan 20
empolyee vlan 30
Wlan: Guest
Wlan: Employee
Scott Fella
You can use the PoE ports but
Is not Cisco supported. The ap will have to obtain an ip address on the same vlan as the wlc management interface.
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
Decided not to use the PoE port on the wlc, but used a regular PoE switch instead.
Thanks for you help!
