WLC 2504 there is no RP Port
2 Accepted Solutions
That is correct, the 2504 do not support SSO. Just N+1 HA
BR
Sandeep Choudhary
As other mentioned that 2504 WLC dont support AP/Clinet SSO, it just support N+1.
Here is the my post for N+1 implementation on 2504:
https://rscciew.wordpress.com/2014/06/07/n1-high-availability-configuration-on-cisco-2504wlc/
Dont forget to rate helpful posts
8 Replies 8
To my knowledge the 2504 does not support AP SSO.
http://www.cisco.com/c/en/us/support/docs/wireless/2500-series-wireless-controllers/113034-2500-deploy-guide-00.html
BR
Thanks ALL,
For connections of Both Controller can we connect to port 2 of wlc 1 and port 2 of wlc 2 through cross cable or straight Cable.
please correct me if am wrong
And Here in option 43 we have two ips of two controllers
In AP sso each one ip for both controllers in option 43
No, You dont need to connect any port between wlcs.  Just setup both controller in N+1 as per my last post.
2504 dont support AP SSO.
Set both WLC IP in hex format in option 43
Thanks Sandeep
one question
I make Mgmt Vlan as untagged in wlc  and in core switch i make as access mode port(vlan20) for wlc 1 and wlc 2
in core int ten1/0/12
             switch mode access
            switch access vlan 20
for ssid vlan in microscoft server 2003 i am not able to get ip add for client
when change  ssid vlan for mgmt for testing it is taking ip for clients
please advice
Configure the switch port as trunk where WLCs are connected:
Example: WLC mgmt interface : 20 and client vlan is 60
so config looks like this:
interface GigabitEthernet1/0/1
description Trunk Port to Cisco WLC
switchport trunk allowed vlan 20,60
switchport mode trunk
no shutdown
*** Normally i tag the wlc mgmt vlan
Thanks Sandeep
Sandeep Choudhary
