WLC 4402 and SNMP values
gmoroni
Hi all,
I need to change via SNMP v2C the value of the PSK for WPA/WPA2 for a specific SSID.
How can do that ?
Tnx a lot for an answer
5 Replies 5
ericgarnel
Level 7
Level 7
Do you have a wireless control server? It would do it for you. Otherwise, you would have to determine the proper OIDS & other info and use an snmpset to do it via snmp 2c read/write community. You would most likely have to snmpwalk the controller and weed out the correct string to get the values for the ssid
Hi eric,
tnx for the answer
actually I don't usa a WCS.
But if it can simplify my life about SNMP for WLC... why not.
The WLC will make your life easier as you add more controllers & APs. I have 4 controllers and the WCS, but still make my changes on the controllers out of habit.
jmmerritt
The method I have used is;
snmpwalk -c -v 2c enterprises.9.9.512.1.1.1.1.4
This will return an index list of the SSID's that you have defined on the controller. Ie;
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.1 = STRING: "Widget Inc."
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.2 = STRING: "Guest"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.3 = STRING: "Lab"
Then, set the PSK of the SSID based on the index value (the last number in the OID) ;
ie.
snmpset -c -v 2c enterprises.9.9.521.1.1.1.1.7.x i 3 enterprises.9.9.521.1.1.1.1.8.x string
where x is the index value.
So, for example to set the Guest SSID for controler 10.10.1.1;
snmpwalk -c -v 2c 10.10.1.1 enterprises.9.9.512.1.1.1.1.4
returns;
2 is the index value for the Guest SSID.
To set the PSK to 0011001100 (not recommeneded!) then;
snmpset -c -v 2c 10.10.1.1 enterprises.9.9.521.1.1.1.1.7.2 i 3 enterprises.9.9.521.1.1.1.1.8.2 string 0011001100
I hope that explains it easily enough.
If anyone can find a way of reading back the PSK once set, I'd be grateful! I haven't been able to do that yet!
Denis Orlov
If someone need to change PSK key for WLAN using SNMP, the working example is bellow. I hope this save time for somebody and you can take a cup of coffie instead spend time in Google, trying to find correct solution.
1) First of all using snmp we can get id of each existing WLAN:
snmpwalk -v 2c -c test123 x.x.x.x enterprises.9.9.512.1.1.1.1.4
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.1 = STRING: "WLAN1"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.2 = STRING: "WLAN2"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.3 = STRING: "WLAN3"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.4 = STRING: "WLAN4"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.5 = STRING: "WLAN5"
SNMPv2-SMI::enterprises.9.9.512.1.1.1.1.4.6 = STRING: "WLAN6"
2) Than, we can set PSK for specific WLAN using this command:
snmpset -v 2c -c test123 x.x.x.x  enterprises.9.9.521.1.1.1.1.7.5 i 3 enterprises.9.9.521.1.1.1.1.8.5 s "94621518"
where
"test123" - snmp RW community
"94621518" - new PSK for our WLAN
"x.x.x.x" - WLC IP-address
P.S. Tested on Cisco AIR-CTVM-K9 with OS version - "8.1.102.0"
