WLC 5508 and Cisco Aironet 1242 LWAPP AIR-LAP1242AG-A-K9
nairsathees
i have deployed wlc 5508 ( image 7.0.98.0 ) with 1262N AP and all 45 AP's are working fine,
at the same site i had AP1242 which i have converted to LWAPP (8 of them), these accesspoint are registerd perfectly with 5508 but non of the radio's are up. i have selected different countries according to the part numbers but unfortunaly non of the radio's are coming up, pleaes help
Sathees
Ha ha very old!! please upgrade the code on the switch and see if that helps!!
Surendra
Surendra BG
26 Replies 26
Nicolas Darchis
What model are your 1260s ? Also -A domain ?
what country did you configure on your WLC ?
Can you provide debugs ?
Traplogs and mslogs from the WLC. Console output of the APs when they are joining the WLC ... but also "debug capwap events enable" and "debug capwap errors enable" taken on the WLC when they join
AIR-LAP1262N-E-K9
US,CA,RU,GB
i will update with logs, by tomorrow
AP's are joining correclty but Radio's are DOWN
One radio down or ALL radios are down?
If all radios are down then what switch model is the AP connected to?
all the radio's are down, connected to 3560 poe switch,
Since there's nothing to lose and both radios are down, can you connect a console cable to the AP?  Reboot the AP and post everything from the power up to the "sh logs".
please find attached AP console out put when its switched on
1)*Mar  1 00:00:13.199: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Mar  1 00:00:13.199: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
2)*Mar  1 00:00:33.856: %CDP_PD-2-POWER_LOW: All radios disabled - HIGH_POWER_CLASSIC_NOT_CONFIGURED WS-C3560-48PS (0012.daea.3cb2)
For the first one, it would seem that you disabled the radios through the WLC web gui ?
For the second, I have to say I never faced that message.
i have tried enabling the radio from the controller but its automatically change back to disable mode
the second message it seems pointing to the POE issue but the 3560 swith has only 4 AP's are connected so there wont be any sufficient power issue
I'm with Nico on this.  ON your 3560 can you post the command "sh power inline" please?
Available:370.0(w)  Used:32.4(w)  Remaining:337.6(w)
Interface  Admin    Oper     Power        Device           Class
                            (Watts)
Fa0/1      auto  off           0.0  n/a                  n/a
Fa0/2      auto  off           0.0  n/a                  n/a
Fa0/3      auto  off           0.0  n/a                  n/a
Fa0/4      auto  off           0.0  n/a                  n/a
Fa0/5      auto  off           0.0  n/a                  n/a
Fa0/6      auto  off           0.0  n/a                  n/a
Fa0/7      auto  off           0.0  n/a                  n/a
Fa0/8      auto  off           0.0  n/a                  n/a
Fa0/9      auto  off           0.0  n/a                  n/a
Fa0/10     auto  off           0.0  n/a                  n/a
Fa0/11     auto  off           0.0  n/a                  n/a
Fa0/12     auto  off           0.0  n/a                  n/a
Fa0/13     auto  off           0.0  n/a                  n/a
Fa0/14     auto  off           0.0  n/a                  n/a
Fa0/15     auto  off           0.0  n/a                  n/a
Fa0/16     auto  off           0.0  n/a                  n/a
Fa0/17     auto  off           0.0  n/a                  n/a
Fa0/18     auto  off           0.0  n/a                  n/a
--More--
                            (Watts)
Fa0/19     auto  off           0.0  n/a                  n/a
Fa0/20     auto  off           0.0  n/a                  n/a
Fa0/21     auto  off           0.0  n/a                  n/a
Fa0/22     auto  off           0.0  n/a                  n/a
Fa0/23     auto  off           0.0  n/a                  n/a
Fa0/24     auto  off           0.0  n/a                  n/a
Fa0/25     auto  off           0.0  n/a                  n/a
Fa0/26     auto  off           0.0  n/a                  n/a
Fa0/27     auto  off           0.0  n/a                  n/a
Fa0/28     auto  off           0.0  n/a                  n/a
Fa0/29     auto  off           0.0  n/a                  n/a
Fa0/30     auto  off           0.0  n/a                  n/a
Fa0/31     auto  off           0.0  n/a                  n/a
Fa0/32     auto  off           0.0  n/a                  n/a
Fa0/33     auto  off           0.0  n/a                  n/a
Fa0/34     auto  off           0.0  n/a                  n/a
Fa0/35     auto  off           0.0  n/a                  n/a
Fa0/36     auto  off           0.0  n/a                  n/a
Fa0/37     auto  off           0.0  n/a                  n/a
Fa0/38     auto  off           0.0  n/a                  n/a
Fa0/39     auto  off           0.0  n/a                  n/a
Fa0/40     auto  off           0.0  n/a                  n/a
Fa0/41     auto  on           15.0  cisco AIR-LAP1242AG  Class 3
--More--
                            (Watts)
Fa0/42     auto  off           0.0  n/a                  n/a
Fa0/43     auto  on            5.8  cisco AIR-LAP1242AG  Class 3
Fa0/44     auto  off           0.0  n/a                  n/a
Fa0/45     auto  on            5.8  cisco AIR-LAP1242AG  Class 3
Fa0/46     auto  off           0.0  n/a                  n/a
Fa0/47     auto  on            5.8  cisco AIR-LAP1242AG  Class 3
Fa0/48     auto  off           0.0  n/a                  n/a
What the ... ?
do i need to do some settings here? or i should use Power Injector?
Please go to the WLC WEB GUI, and Wireless and then click on the Concerned AP and then Advanced..
Please post the screenshot from AP-Advanced, i just wanted to see the  Power Over Ethernet Settings, make sure you check Pre-Standard State if we are using POE or Check Power Injector State if we are using Power injector and see if that helps!!
Surendra
Surendra BG
its on POE mode i have checked the same
