WLC 5508 Management Interface not seeing default gateway
keith.k.quaye
I am installing a new  5508 controller and  i have a management  interface mapped to  port 1  and serveral wlans also tied to port 1. Port 1  is trunked to the Core switch. I am able  to ping  the wlans from the core and ping their default gateways  from the  controller.  I am unable to ping  default gateway of the maanagement  interface.. I can't seem  figure out why.
12 Replies 12
Surendra BG
pleasepost the switchpost configuration to which the WLC is getting connected and fro mthe WLC paste the output "show interface sumary"
Looking forward to hear from you!!
Surendra
Surendra BG
Surendra   here is the information requested
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
buildiing150                     1    51       10.106.51.198   Dynamic No     No
building-a                       1    31       10.106.31.198   Dynamic No     No
building-b                       1    41       10.106.41.198   Dynamic No     No
building12                       1    21       10.106.21.198   Dynamic No     No
building130                      1    81       10.106.81.198   Dynamic No     No
building14                       1    11       10.106.11.198   Dynamic No     No
hangar11                         1    71       10.106.71.198   Dynamic No     No
hangar5                          1    61       10.106.61.198   Dynamic No     No
management                       1    untagged 10.106.32.198   Static  Yes    No
service-port                     N/A  N/A      192.168.1.1     Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
Swiitch port config that is connected to WLC
interface GigabitEthernet0/1
switchport mode trunk
end
Please specify the native VLAN on the switchport configuration.. that is..
switchport trunk native vlan #
end
And let me know if we are able to ping
Surendra
Surendra BG
Your management is in VLAN 1, and that is the native vlan on the switch as well.
on the switch, do a switchport trunk native vlan 999.  then on the WLC tag the interface as VLAN 1.
Cheers,
Steve
If  this helps you and/or answers  your question please mark the question as "answered" and/or rate it, so  other users can easily find it.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks for your replies  I fixed it by tagging  the management  vlan   since its in vlan 32 I  changed it from untagged.
On a different note I  got everything almost set up and the   APs are joining the controller  but  I do not see the  SSID when I  look at the available  wireless networks  on my notebook. Any  reeasons why ?
From the WLC..
GUI >> WLAN >> WLAN EDIT >> General >> Broadcast >> Check.
Lemme know if this helps! please dont forget to rate the usefull posts!!
Surendra
Surendra BG
This has resolve my issue too. Thanks a lot
Surendra,
Thanks for your quick response  but I do believe  I verified that  it was checked.  and thats what  confused me. I am not in front of the system but I will  check agaiin
No problem.. lemme know how it works out for you!!
Surendra
Surendra BG
I found out the problem  each WLAN had the same SSID I gave them each a unique ID  to characterize the building they covered  and that resolved it. Thanks for your time
recep.sefer
I have the same situation
but my switch is HP Procurve
Two 1-gig interface is connected to
Is there any working HP config
Hello Surendra
I have smilar problem with WLC 5508 with Software Version 7.0.116.0. I am unable to ping my default gateway. I have verfied that we dont have any static routes. I can access WLC through HTTP and SSH not via HTTPS even after its enable.
Here are switch config
Building configuration...
Current configuration : 254 bytes
interface GigabitEthernet2/41
description usgrnwlc01
switchport trunk native vlan 100
switchport trunk allowed vlan 100,250,251
duplex full
qos trust dscp
channel-group 11 mode on
end
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Gu        est
management                       LAG  untagged 10.143.72.250   Static  Yes    No
service-port                     N/A  N/A      0.0.0.0         DHCP    No     No
virtual                          N/A  N/A      0.0.0.0         Static  No     No
