WLC 5508 TPC - Can Power Level Assignment Method be set in RF Profile?
magurwara
Re: 5508 WLC Tx Power Control(TPC)- High Density Deployment
My Client's WLC is globally set to Fix AP power level to level 1.  Is it possible to change this setting on an AP Group basis?  Want to auto adjust power for a certain location.  I have created the AP Group for that location and set specific RF Profile, but the RF profile only has min and max power settings, not the control to do fix or Auto power adjustment.
WLC 5508, APs = 1142, 2802, 2602
Thanks.
5 Replies 5
Leo Laohoo
Nope. That sounds like each AP needs to have their Tx power manually configured.
My recommendation is to use CLI.
Thanks Leo.
If I understand correctly you are saying to configure each AP with a specific power level.
There is no Auto-Power level adjustment command on AP level either?
If you are using RF Profiles, then set the max and min to the same dbm. That is basically setting a fixed power level. Or else just manually set the power level on the access point itself.
-Scott
Thanks Scott for the tip.  In my case I don't want to fix power to a certain level but want the AP's to automatically adjust according to the surrounding environment.
This of course can be set globally, but I was looking to do it for a subset of APs.
Looks like there is no way practically to achieve what you wish to.. RF profiles are the only way to configure a different RF setting for a subset of APs . However, RF profiles don't have an option of configuring the TPS mechanism like automatic/on-demand/Fixed..  This may qualify for an enhancement request for Cisco .. :)
Cheers,
Manish
