03-27-2020 02:32 AM - edited 07-05-2021 11:53 AM
wlc 9800-CL and a registered C9130AXI-E (aptest1) & AIR-AP2802I-E (aptest2)
At this moment we are in test fase for deploying C9130AX series AP's. The 9800-CL is running version 17.1.1s.
1. The C9130AXI is not visible as a Dual-Band radio. The 2802I is.
wlctest-01#show ap dot11 dual-band summary
AP Name Mac Address Slot Admin State Oper State Width Txpwr Mode Subband channel
aptest2 2c5a.0f55.d040 0 Enabled Up 20 *1/6 (16 dBm) Local All (1)*
2. Country code correct?
wlctest-01#show ap status
AP Name Status Mode Country
aptest1 Enabled Local NL
aptest2 Enabled Local NL
In a Linux client: sudo iw dev wlan0 scan
The 9130AXI is the country: Country: NP Environment: bogus
The 2802I is: Country: NL Environment: Indoor/Outdoor
Check with a Fluke Aircheck shows the same.
03-27-2020 08:19 AM
03-27-2020 08:23 AM
03-30-2020 01:12 AM
Thanks Scott for your help. I think the confusing started in this document: https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/deployment-guide-c07-743490.html#Legacyantennasupport
What I like to do/try is showed in Figure 30 en 31. Splitting 1x (8x8) to 2x (4x4). The next (rather blurred) screendumps are not what I see on my controller.
Stay safe and kind regards.
03-30-2020 02:27 AM - edited 03-30-2020 03:54 AM
Adding a thought, Is it possible that a 9130AX AP needs additional power. > 30W (802.3at PoE+)? (The specifications states that
802.3af (15.4W) the radio's are 1x1)
03-30-2020 08:02 AM
03-30-2020 08:14 AM
04-03-2020 12:52 AM
All seemed to be fixed in 17.2.1 release. So that's nice. Thx.
