04-23-2014 03:40 PM - edited 07-05-2021 12:44 AM
I am getting en error with my 5508s in a HA pair that cropped up after 62 days of running. I tried to add a new SSID and then i saw these errors in the logs.
Running version 7.4.121.0
I copied my standby running-config and also copied my primary config. When I compare them both I can see my new SSID that I created but it does not have my older SSIDs created 62 days ago. Mainly changes as related to my older WLANs are not sync'd.
I opened a TAC case and they are researching the problem but I fear they are going to tell me to upgrade code or rebuild my HA pair. I was hoping that somebody might have run across this and can suggest a command that might "force" the configs to sync up.
I was also going to try and reboot the standby box and see if the reboot causes it to sync again. maybe there's a flag saying the earlier SSIDs are sync'd when they are really not. I also fear that when I do this it will just drop out and not sync back up. Which might lead me to breaking the pair and rebuilding it again.
To sum it up it seems like new changes are being sync'd but all others that were present before the changes are not present on the standby.
~Thanks
Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbApfWebAuthServerPrecedenceSet, | |
3 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapLdapServerDeleteAtIndex, |
4 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapLdapServerDeleteAtIndex, |
5 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapLdapServerDeleteAtIndex, |
6 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapSessionTimeoutSet, |
7 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmdbApfVapWebPassthroughEmailInputSet, |
8 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbWebCustomizationsGlobalStatusSet, |
9 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapWebAclSet, |
10 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapWebAclSet, |
11 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbApfVap80211rFtSupportModeSet, |
12 | Wed Apr 23 15:18:13 2014 | RF failure notification ErrorType: 32 Reason :Error: Config Sync failed on Standby for the usmdb:HA_send_usmDbVapSecurityPolicySet, |
04-24-2014 01:19 AM
