WLC Version & DHCP Problem
jheckart
Level 6
Level 6
I have implemented WLC w/WCS to manage 20 1231G's. The 1231G's are currently autonomous, and will be converted tomorrow. In my testing, I ran into the problem of DHCP on another server dying after a certain period of time. I have upgraded to 3.2.195.10, and have not seen the DHCP problem again. Has this issue been fixed in 3.2.195.10, or should I expect to see it again.
If it's still an issue, I will just use DHCP on the device.
Thanks.
jheckart
Level 6
Level 6
I looked in bugtraq, and found that this is still an issue. Does anyone have any idea when this is supposed to be fixed?
Also, is my 3.2.195.10 the best version to move forward with for the time being?
Thanks.
fredn
I'm not aware of a DHCP problem with that version. If you suspect it's an issue, I'd check the release notes or perhaps open a TAC case (as they track these sorts of things).
I think you are talking about CSCsf32185.
4.0.216.0 is available for download, but I have not reviewed the release notes to verify if 216 contains the bug fix.
